Introduction: How to Make Your Own Biodiesel:
Info & Facts:
This method works well if you need a max of a few liters of oil, like for a science fair project or small scale set-up.
All Steps based on 3 gallons of algae solution/culture. Algae content within culture varies, depending on thickness and opaque-ness of culture before oil extraction begins.
Algae oil is harvested in a variety of ways, but this is the easiest way for small scale biodiesel production, or algae oil harvesting.
Algae oil is called lipid oil, and it is found within the algae cell itself. You must break the resilient cell wall to release the oil. Some strains can contain around 60-70% oil, while others contain very little. Picking a stain is dependent on 3 factors: Time it takes to grow, hardy-ness or easiness of growing it, and the percentage of oil within each algae cell. I prefer the following strains: Chlorella vulgaris, Scenedesmus quadricauta, and Nannochloropsis oculata. There are a few places online I have found to be convenient in buying algae, listed later in this instructable.
Comment for questions---This is the brief version of how to do this, instructables crashed and did not save my work first time around.
Step 1: Vegetable Oil Biodiesel
Vegetable Biodiesel:
Time: should take 1-2 hours
****MUST wait 2 days to let the biodiesel settle/separate before burning.****
This can be scaled down using ratios of desired amount of oil: NaOH and oil: Methanol
The below process is called a transesterification reaction.
1. Warm 100ml of oil (pick one) on a hot plate 50 degrees centigrade (10-15min)
2. Use a mortar and pestle to ground sodium hydroxide pellets into a fine powder
3. Measure out 0.35 grams of sodium hydroxide
4. Use a graduated cylinder to measure 20ml of methanol
5. Pour the methanol and the sodium hydroxide into 250ml (or larger) Erlenmeyer flask with a magnetic stirrer bar inside
6. Place solution on a magnetic stirrer plate and wait for the sodium hydroxide to completely dissolve into the methanol (5-10 min)
7. Cover solution to avoid dilution (Sodium Hydroxide + Methanol = Methoxide Solution)
8. Pour warm oil into the methoxide solution while it is still on the magnetic stirrer plate.
9. Keep stirrer on medium for 30 minutes
10. Place solution on a hot plate at 50 degrees centigrade (while stirring)(If using a digital hotplate, it should be set to ~65 C)
11. Wait two days for the glycerin to separate from the oil
12. Remove Glycerine with a pipette from the bottom of the beaker (the glycerine is a dense, darker, thin, layer that appears at the bottom of the beaker after allowing the solution to settle for 2 days)
13. What is left is biodiesel.
If the oil you use is mainly saturated (very thick or even solid at room temp.), there will be more than 2 layer after two days of waiting/sattling od solution. The very bottom think/dark layer should always be removed. Any other layers can be re-mixed, or you can just use the least sense layers, either way, all layers (except the bottom gycerine layer) are part of the biodiesel and will burn. The issue of including/mixing the layers of biodiesel is that they are of different density, so if the fuel sits for too long it will stratify again and the densest layer will require the most energy to combust. Another thing to consider, you don't want fuel the consistency of honey in your car.
Step 2: Algae (Lipid) Oil Biodiesel
Algae Biodiesel:
Time: Hours, Like a ton of time
~4 hours to pressure cook 3 gallons of algae culture solution
~2 hours to microwave remaining 3 gallons from pressure cooker
~10min to stir in alcohol
~1 hour to boil off remaining water and alcohol
1. Pressure cook algae solution
-Any food grade pressure cooker will do
-This step is not necessary, but helps speed up the process because it gets rid of a lot f excess water in the algae solution
-I filled my pressure cooker to the recommended max amount and then cooked each batch 3 times, for 75-100min each time
-You can cook for longer or shorter depending on your specific pressure cooker, just be sure not to vaporize off too much water
2. Microwave Algae solution
-Do this in small batches in bowls that fit into your microwave. Do not over fill your microwave.
-Pyrex bowls with handles work well
- I put it in the microwave in 1Liter -ish sized batches, for 15-25 min at a time
-Once it gets down to about 100ml, i decrease the time interval to 5-10min
- I stop microwaving when it reaches about 50ml, then i start the next batch
-This breaks the algae cell walls, releasing the lipid oils within.
3. Add alcohol to algae solution
- I pour the microwaved algae solution into a rubbermaid container and then for every 4 parts algae solution, I add 1 part isopropyl alcohol (any alcohol will do, the higher the concentration the better, but 70-99% is what I use)
-Mix it for 3-5min
-let it sit for 3-5min
-Alcohol further eats away algae cell walls
4. Boil down algae solution
- Use a tall sided pot on the stove, with a small radius (if possible, this just makes it easier in the end)
-DO NOT pour anything containing alcohol near an open lame, like a gas stove
-pour the alcohol-algae solution into the pot
-heat to a boil, alcohol will boil off first. BE CAREFUL it tends to bubble and boil over easily and quickly.
-Try to boil off the alcohol first (it will smell, open window/use fans for ventilation)(it irritates eyes if put your head directly over the pot)
-Higher heat will e required to boil off the water
-Once it gets very near to the bottom of the pot, you may want to switch t a tiny 8" diameter pot or less to boil off the rest of the water/alcohol
-it should get very thick, and look green and slimey, mixed with varying amounts of yellow/brown liquidy oil. It will feel greasy between your fingers. This is OKAY. there will not be a ton of oil there. It will be CRUDE (thick, it contains the algae cell remains, which is okay)
-BE CAREFUL not to over-boil this step, it will start to boil off the oil, and you need that not to happen, so make sure it doesn't get too low/dried out
Store in a covered conatiner.
See STEP 1 (Vegetable Oil Biodiesel) for the basic transesterification reaction to turn oil into biodiesel.
-Mix it for 3-5min
Step 3: Resources
Places to find Algae to start our cultures and/or make your own photobioreactors:
-http://www.nilesbio.com/subcat103.html
-http://www.carolina.com/algae/green-algae-ac-living/FAM_151955.pr?catId=10635&mCat=10476&sCat=10634a7intid=srchredir_algae&ssCat=&question=
-https://www.wardsci.com/store/catalog/product.jsp?catalog_number=860600
**(Highly Recommended)***-http://www.ebay.com/itm/LIVE-ALGAE-FOR-BIOFUELS-OR-HEALTH-FISH-FOOD-PROBIOTIC-OR-RESEARCH-/181059007474?pt=LH_DefaultDomain_0&hash=item2a27f533f2
Links and resources for help and research:
- http://iopscience.iop.org/1748-9326/8/2/025022
-http://science.howstuffworks.com/environmental/green-science/algae-biodiesel2.htm
-http://www.oilgae.com/algae/comp/comp.html
-http://microbewiki.kenyon.edu/index.php/Biodiesel_from_Algae_Oil
-http://www.treehugger.com/renewable-energy/make-your-own-algae-for-biofuel-using-recycled-drink-bottles-video.html
-http://www.algaelab.org/
-http://peswiki.com/index.php/Directory:Biodiesel_from_Algae_Oil
-http://www.utahbiodieselsupply.com/tutorialvideos.php
-https://www.instructables.com/id/Simple-Algae-Home-CO2-Scrubber-Part-1/
-http://www.originoil.com/pdf/OOIL_World_Biofuels_Markets_100316.pdf
