Introduction: How to Mount Theatre Chairs for Free-Standing Installation
Typically for home theaters this type of chair is bolted directly to a concrete floor or to a larger wooden platform, but this instructable allows for greater flexibility for use in a multipurpose room. The first time that I mounted these chairs I installed them all together on a single MDF deck cut from a 4'x8' sheet, but this time I chose to use stock, pre-cut birch veneer plywood so that the chairs could now be separated and moved around the room individually. Like my previous install, I mounted the chairs at a slight angle to the deck base.
Step 1: What You Will Need.
Materials:
- 3/4" x 2' x 2' birch veneer plywood (1 per chair)
- 1/4"x 1" bolts (4 per chair)
- 1/4" x 1" washers (4 per chair)
- 1/4" lock nuts (4 per chair)
- smaller 1/4" washers (optionally used as spacers)
(I started with bolts of various lengths because that's what I had at hand and used a
hacksaw to cut the bolts flush once installed, but the 1" lengths worked without needing
a trim.)
Tools:
- electric drill
- 1/4" wood drill bit
- 1" wood drill bit and black electrical tape (see image note)
- 7/16" socket and wrench
- pencil
- saw horses
Step 2: Decide on Placement, Mark and Drill Holes.
Decide on placement and mark. Once you have decided on the position of the chair, mark your holes with a pencil. I tried to keep 1/2"+ from the edge and chose to mount the chairs at an angle to the base. You might want to mark the wood where the front of the chair will be so that it's easy to line up the holes when you are ready to mount.
Drill holes. First drill the 1/4" holes and then turn the board over to the bottom of the base to drill the 1" holes to the depth that you marked on the drill bit.
Step 3: Attach Chair to Base.
Put the base on saw horses (or two bar stools like I did) and line up the mounting holes on the chair with your 1/4" drilled holes in your base. Your 1" holes should be accessible from the bottom. With your holes aligned, push the 1/4" x 1" bolt into the hole and put the 1" washer and 1/4" nut on the underside using the socket and wrench to tighten.
Fire up the popcorn popper and silence your cell phone...you're ready for movie night!
6 Comments
8 years ago on Introduction
These look great! Any tips for cleaning old chairs? I recently got half a dozen from a local theater that's doing some renovations.
Reply 7 years ago
I get all my chairs are used from theaters that are replacing chairs from the 1970s. I use resolve and a rag and scrub them for about a hour. That way I get more seats for less and get the years of soda stains out.
12 years ago on Introduction
Just wanted to say thanks, I just mounted my theater chairs today. Nice instructions!
Reply 12 years ago on Introduction
That's awesome! So far I haven't had any problems with the mount and it has been nice to be able to move them around for parties. Now everyone gets an aisle seat. Thanks for the note and happy viewing.
where did you find theater chairs?
It's been several years, but I think it was seatsandchairs.com. Some folks get lucky and find a local venue remodeling or closing. Mine are refurbs and have a seat number plate on them...makes for interesting conversation when thinking about the history of the chairs.
