Introduction: How to Operate Niftymitter V0.24
This instructable will tell you how to operate Niftymitter 0.24, a small open source FM transmitter. More information on the design can be found at www.openthing.org/products/niftymitter.
This transmitter is in development and has not yet been approved by any regulators. It is a low power transmitter and works over a very short range - please ensure that by using it you are not interfering with any other nearby transmitters.
Step 1: Plug in a Source
Step 2: Switch On
Step 3: Tune In
Make sure your transmitter and radio receiver are at least 2m apart to avoid tuning in to a harmonic frequency. Switch on your radio and tune the radio in to the transmitter. This should be broadcasting on a frequency between 88 and 91 MHz FM, transmitting silence.
It is difficult to be accurate here as: a) the frequency can very depending on atmospheric conditions and b) the scale on your radio might be calibrated differently to the scale on my radio, so would give a different reading of what frequency it is receiving on.
If you are having difficulty tuning in, you may need to retune the transmitter, which is described in step 5.
Step 4: Turn It Up!
Carefully turn up the volume on your audio source to a comfortable level. If you turn up too loud, the signal will sound distorted (it really doesn't need to to be very loud).
Step 5: To Retune Niftymitter
Slide out the circuit box.
Use a small 3mm slot headed screwdriver to adjust the 'trimcap'. It is best to use a screw driver with an insulated handle to minimise interference with the transmitting frequency, or ideally a trimtool such as this one from Rapid.
The trimcap is a small brass coloured component accessed by the hole marked 'tuning'. Clockwise for up, andticlockwise for down, it only requires very fine adjustment.
Step 6: To Replace the Battery
Slide out the battery tray. Unclip the battery from the PP3 clip, recycle/recharge and replace.
