Introduction: Paper Mache Clock
hello everyone, welcome to FIRST TIME my Instructable!
Step 1: What You Need:
The things needed for this project are easy to find and method also very easy.
- flour
- water
- mixing bowl
- spoon
- old newspapers
- Hair Dryer
- Using Aluminum Foil
- Plaster Craft Paper if you necessary
nitrile rubber glove if you necessary
clock movement kit if you necessary
Step 2: How to Make a Hand Tin Out of Foil
The easiest way to make a hand out of tin foil and tape if you need... is to stack three sheets of foil and press them into your hand to make a mold as you can.
Mix one part flour with one part of water, until you get a thick glue-like consistency. Add a bit more water if it's too thick. Mix well with a spoon to get rid of all the lumps. you can use a small kitchen electric mixer to whiz them out.
PRETTY EASY!
You need to use strips of newspaper only, or even paper tissues or towels.
Dip a strip of newspaper into the mixture or hold it over the bowl so it drips back into the container.
Step 3: Repeat and Repeat
Do this until the entire surface or figure is covered three times over. This is especially important if you're removing the base when it's dry (hair dryer)* -- it needs to be sturdy and hold its own.
Step 4: Preparing to Make the White Shiny
Cut the bandage plaster into strips with scissors.
When you are finishing cutting the plaster strips, place them in a bowl or use Travel Mister Bottle if you like....
Dip the strips into a bowl, one at a time. Use your finger to run excess water off the strip. You want the strip to be wet, but not soaking. Pretty Simple!
Step 5: Decorating Idea
Easy diy clock decorations~
Not be hard on yourself
