Introduction: Easy Pen Arrow
So,Hello everybody!
A friedPotato instructable here, about How to create a Pen Arrow...
--------------------------------!•CAUTION•!---------------------------------------------------
-This instructable can be really dangerous, so take care when using it!
-NEVER use this "weapon" against other people! It could KILL someone!
Have FUN! :)
Step 1: Step #1 - Material
To make this instructable, you are going to need:
-A Pen tube
-A Refill
-Some  Rubber bands -or- Duct tape
- - -- - - - -- - - - - - -- - -  - -  NOTES - - - - - - - ---- - -- - - - --- - -
*You should have at least 2 Rubber bands, one of which is recommended to be thick and/or hard*
*The Duct Tape is not recommended, due to its stability...*
*The refill should have a thickness less than the tube, so that it can fit in..*
Step 2: Step #2 - Attaching the Rubber Band
Take a Rubber Band (The thickest if there is one), and apply like shown.
*The Rubber Band, should not be placed twisted, or else it might not work at its best*
*If the Rubber band cannot be applied or falls down, try a shorter one -OR- take a longer tube*
Step 3: Step #3 - Other Rubber Band(s)
Now, take the other Rubber Band(s) and attach it to one end of the tube, over the first.
*More Rubber Bands attached = Better stability..but do not overdo it*
Step 4: Step #4 - Rubber Band Off
Take the Rubber Band off the side you attached theother Rubber Bands.
(This is necessary, because you must open one side of the tube, for the Refill to sling)
Step 5: Step #5 - Load N' Rdy 2 Go!
That's it!
Now, place the Refill in the tube, stretch the Rubber Band and DONE! :)
*When Stretching the Rubber Band, you should grab the Refill too...*
