Introduction: How to Pick the Best Soldering Iron
A soldering iron is a hand tool used in soldering. There are many soldering irons available on the market. They come in a variety of sizes and shapes. Which soldering iron to choose for yourself depends on the soldering projects you are planning to do, as well as how often you are planning on using it. This Instructable will cover choosing a soldering iron that will be used for projects in electronics for soldering and de-soldering work on the circuit boards.
The four main factors to consider when choosing a soldering iron are:
1) wattage
2) type of the soldering iron
3)temperature control
4) tip size and shape
Wattage
The wattage of the soldering iron is one of the most important factors in a soldering iron. Most of the soldering irons used in the electronics are in the range of 20 – 60 Watts. Soldering iron with a wattage of 50W is very common these days and it will provide sufficient heat for most of the soldering projects on the circuit boards. Soldering irons with higher wattage (40W -60W) are better. It does not mean that soldering irons with higher wattage apply more heat to the solder joint- it means that soldering irons with higher wattage have more power available. Since most soldering stations come with a knob on the power station for setting the iron’s temperature, it is possible to regulate the amount of the heat on iron tip. On the other hand, soldering iron with low wattage (20W - 30W) can lose heat faster than it can re-heat itself - this results in bad solder joints.
Types of soldering irons
Generally, there are 4 different types of soldering irons:
-Soldering pencil
-Soldering station
-Soldering systems (rework /repair stations)
-Soldering guns
Step 1:
Soldering pencils
Soldering pencils are a very simple (and very cheap) soldering tool that can be used only for simple do-it-yourself projects. The price of the soldering pencils is in the range of $10-30. I do not recommend soldering pencils for fine soldering projects since they do not provide any control of the temperature on the iron tip. Too much heat applied during soldering can damage components and peel off tracks on the circuit board.
Step 2:
Soldering stations
A soldering station consists of a soldering pencil attached to a power station. The power station has controls for setting the desired temperature on the tip of the soldering iron. Some of the soldering stations come with electronic temperature control - that means you can very precisely set and maintain the temperature of the iron. The power station automatically keeps the iron tip at an appropriate temperature. The price of the soldering stations is in the range of $ 40-150. A soldering station can cover most of the soldering projects including soldering of through-hole components, and very fine surface-mount components as small as 0603 and 0805. Weller is the most popular brand for soldering stations followed by Hakko. On the other hand, the Aoyue soldering station is a good combination of quality and price.
The most popular models of soldering stations are the WE1010NA Weller soldering iron, FX-888 Hakko soldering iron, and Aoyue 937.
WE1010NA Weller soldering iron is the latest model of soldering iron from Weller. It is an improved version of the WESD51 Weller iron.
Step 3:
Rework/repair systems
Rework/repair systems are complex soldering systems that are mostly used in industry or in high-volume manufacturing facilities. Soldering systems usually consist of several hand pieces including soldering iron, hot-air gun, de-soldering gun, thermo-tweezers, etc. The price of the soldering systems is in the wide range of $250 - $2500. The Pace is the most popular brand for these soldering systems. Popular models of rework/repair systems are Pace MBT-250, Pace MBT-350, and Aoyue 2702.
Step 4:
Soldering guns
The main part of a soldering gun is a transformer that converts 110 V AC to a lower voltage. A secondary winding of transformer has only one turn. This way the secondary of the transformer produces very low voltage and several hundred amperes of current since the primary of the transformer is connected to 110 V AC and the secondary winding of the transformer has only one turn. This high current is routed through the copper tip of a soldering gun and as result, the tip of the soldering gun is quickly heated by the high current flowing through it.
Soldering guns can be quickly and easily turned on and off and they have a very short warm-up time. However, I do not recommend soldering guns for fine work on circuit boards since they can generate too much heat and can therefore damage the circuit board or components on them. The price of soldering guns is in the range of $20-70.
51 Comments
6 years ago
Great post and useful were the people can learn much more about soldering iron, Here is a different kinds of solder iron where the people can manage with various projects. Also on this article i find good information may will be good for you how to choose the best Soldering iron for you, have a good explanation of soldering irons and Soldering irons Tips.
8 years ago on Introduction
If people are interesting in do repair in motherboards or any board with IC's or any other chip then the hot gun is a must and they sale really cheap ones on ebay (chinese made).
99% of the electronics we buy/use/depend on here in America, comes from China...the other 1% comes from all them other oriental countries.
There is not one electronic thing sold in America, that is made in America. 99% of everything we buy(except for the food) comes from over seas...That other 1% is the food.
Reply 7 years ago
That is very sad! :( I did some soldering in my time, why can't Americans sit on at a workbench and solder all day? I did. WE need those jobs in the US.
Reply 6 years ago
I remember here in the UK sitting at a bench soldering boards for electric blankets, I enjoyed the work so much I was sad to go, (it was gov training scheme) the skills that I learnt meant that I can repair boards should I need to,
Reply 7 years ago
First contruction processes have changed significantly. Where don't seem to understand that I have to question your clam you sat at a work station and soldered all day. Modern circuit boards are constructed automated processes. A machine place solder past on the appropriate pads another machine place the parts on the bord, then the board is then sent to an oven where the past is heated to where the paste flows thereby soldering the component to the board
Reply 7 years ago
Americans can (and do) sit at a workbench and solder all day. The trouble is that the very minimum an American is permitted to work for is significantly higher than what many other countries work for. Your government priced you out of the market a long time ago.
Reply 7 years ago
Because our (American) gov't is so greedy & corrupt, is why all the American jobs went overseas.
The U.S.A. that I have come to know & love is slowly becoming a 3rd world nation.
Our gov't does not give a rip about its own people, they are only concerned with themselves, hence why all the jobs we used to have here are now in the middle & far east.
Reply 7 years ago
https://en.wikipedia.org/wiki/Adafruit_Industries
Reply 8 years ago
Nice station. Can you give me the model number of it? Also, what is the heat gun used for when soldering? I've been soldering for many years for RC applications mostly but find that the Weller heat gun and tips to be too large for many of the smaller projects as u cannot be precise in any way due to their size. What would you recommend? I am a big eBayer and do not mind purchasing items overseas if they are worth it. Thanks for your help
Reply 7 years ago
The heat gun is used for the IC's and if you go to youtube and search for repairing motherboards then you will see how that works, I use it besides computer/laptop boards for playstations (3,4) which I buy on ebay.
You can see on this youtube video one of the uses:
https://youtu.be/AxYhF6Ab2CU
yihua 898d
Really good station and is about the same as my weller.
On the right is a Weller WES51 and I use that one for soldering only, the black one with a heat gun is a Chinese brand I got on ebay, Yihua 898D. See this youtube video I found on the net:
Reply 8 years ago
Nevermind, I see that the Yahua 898D comes in a 2in1 which the blues older ingredients station is a part of. Would that 2in1 unit suffice or did you purchase the WES51 because it was inadequate? Thanks
I use the black one only to desolder but the iron side works really good when I tested soldering a few caps but I always had a Weller and I updated to the 51 a few months ago.
Reply 8 years ago
Thanks for the reply and video. It was VERY helpful. What is the blue block with the yellow handle in between th hot gun and weller? Thanks
6 years ago
Great advice. Really explains the wattage vs tip temp issue clearly. Many kit instructions confuse this for the beginner.
9 years ago on Introduction
Interesting introduction to soldering tools. Thanks.
As for a specific recommendation, I've been using a Goot ks-20r iron for a couple
of decades. It's a simple tool -- no temp control -- but reliable and it does what I
need it to do. Replacement tips are hard to find, but I'm still using the original tip,
which shows no sign of damage or wear.
How do you clean the tips?
"...A small square of damp cellulose sponge works..." this is true, but I have a brass scrubber, like what you might use for washing dishes, that I use for cleaning the tip. it lasts longer & in my opinion, it cleans better. For about $1.50 I get 3 of them per package.
