How to Pirate a Vinyl Record the Hard Way
59,645
285
39
Introduction: How to Pirate a Vinyl Record the Hard Way
About: I am a full-time online content creator, designing, creating and teaching the art of woodworking. I have an art background that I incorporate into my projects and focus on originality and design.
One of my most fun projects to date! I take a Johnny Cash reissue 7” vinyl record and duplicate it with a silicone rubber mold and liquid plastic. To be quite honest I was surprised on how much detail the mold can handle as the duplicated record played almost perfectly. You can listen to the ripped audio on my website. There was a few more pops and clicks than the original record and I’m guessing that’s from dust or not cleaning the original enough beforehand. Obviously pirating and duplicating any copyrighted material is prohibited but in the spirit of making and experimentation this was a fun project.
Step 1: Making the Mold
Nail, screw or glue 4 pieces of wood big enough to hold your record. Here I'm just using plywood and some screws. You'll want it to be an inch or two bigger than your record. The internal dimensions of my mold is 9".
Step 2: Making the Mold
Using some tub and tile adhesive attach your mold to a piece of glass. I'm using a large mirror I have laying around.
Step 3: Caulking the Mold
Now caulk the inside of the mold. This will keep the silicone rubber from leaking out.
Step 4:
Now mix up equal parts Smooth-On Silicone OOMOO 30. This is a silicone rubber compound for making molds. You'll want to mix this thoroughly for 3 minutes.
Step 5: Pouring on the Silicone Rubber
Pour in just enough to cover the record. You'll also want to plug the spindle hole of your record. I'm using a 45 RPM adapter/plastic insert.
Step 6: Brush in the Silicone Rubber
Use a brush to push in the silicone rubber into the record grooves. This will ensure there is no trapped air.
Step 7: Pouring on the Silicone Rubber
Pour in the rest of the silicone mixture making sure everything is covered edge-to-edge. Let this dry overnight.
Step 8: Peeling Back the Rubber
Once the silicone rubber has had a chance to dry overnight carefully peel it out of the mold.
Step 9: Completed Silicone Rubber Mold
You should have a clean mold free of air bubbles. It's pretty amazing how these tiny grooves leave an impression in the silicone rubber.
Step 10: Mixing Up the Liquid Plastic Resin
Now it's time to mix up the liquid plastic resin. I'm using Smooth-On Smooth-Cast 300. Make sure to mix thoroughly and work quickly as the liquid plastic starts to set in just a few minutes.
Step 11: Pour in the Liquid Plastic Resin
Now pour in the liquid plastic resin into the silicone mold. Try your best to keep it from spilling out of the round impression. I did get some spill-over because my bench is not level. This can be cleaned up with a knife or bandsaw later. You'll also want to plug the spindle hole of your record. I'm using a 45 RPM adapter/plastic insert. Let this cure for at least 1 hour.
Step 12: Cutting Off the Excess
Once it has time to cure for at least one hour you can pull it out of the mold. Since I had some spill-over I'm cleaning up the edges on my bandsaw. You could easily do this with a utility knife.
Step 13: Attaching the Label
I took a photo of the label and printed it out on on some shipping label stock. Cut it out with some scissors or an X-Acto knife at attach it to the record.
Step 14: Turn It Up!
And that's it! Put on that record and turn it up! You can listen to a ripped copy of the duplicated record on my website along with many more tutorials!
https://makesomething.tv/how-pirate-vinyl-record-hard-way
Be the First to Share
    • Sculpt & Carve Challenge
    • Meatless Challenge
      Meatless Challenge
    • Fandom Contest
      Fandom Contest
    39 Comments
    ttripp2
    ttripp2
    5 years ago
    Had
    ttripp2
    ttripp2
    5 years ago
    Awesome, only wish you has posted both for comparison
    TonyC88
    TonyC88
    6 years ago
    I was surprised that you were able to do this without removing air bubbles from the silicone compound and the plastic casting. Perhaps you materials were less viscous than the ones I used. Silicone is excellent for picking up fine detail. However, I always used a vacuum pump and jar when I made my molds to release any bubbles, as well as physically removing those I could see.
    Gamer4Fire
    Gamer4Fire
    6 years ago
    The Audio Home Recording Act of 1992 (USC 17.10 §1008) clearly states:
    "No action may be brought under this title alleging infringement of copyright based on the manufacture, importation, or distribution of a digital audio recording device, a digital audio recording medium, an analog recording device, or an analog recording medium, or based on the noncommercial use by a consumer of such a device or medium for making digital musical recordings or analog musical recordings."
    DanyaelD
    DanyaelD
    Reply 6 years ago
    Thank you Buzz-Killington. We're all aware of copyright. Let's just look at the project for what it is, duplicating something from a mold ;)
    rthunder
    rthunder
    Reply 6 years ago
    Or to pull out the relevant parts: "No action may be brought under this title alleging infringement of copyright based on... noncommercial use." The commenter was trying to say, "No worries."
    Gamer4Fire
    Gamer4Fire
    Reply 6 years ago
    You didn't even read my post, did you?
    Make Something TV
    Make Something TV
    Reply 6 years ago
    Wow. You enjoy sucking the fun out of other people's projects? Obviously it's illegal to duplicate and distribute copyrighted work. But just so you know the record label tweeted about this project of mine twice. Let's continue to celebrate the act of experimenting and creativity.
    Gamer4Fire
    Gamer4Fire
    Reply 6 years ago
    The law I cited clearly states that it is LEGAL to make copies of music records for personal use. How is that "sucking the fun out of other people's projects?"
    bryan3141
    bryan3141
    Reply 6 years ago
    While it's exceedingly unlikely that something like this would ever go to court, you should note that the method being used here is ANALOG, not digital and therefore not actually covered under this act.
    cargorilla
    cargorilla
    Reply 6 years ago
    It clearly states "analog". or by "analog", do you actually mean "anally"? in which case it would not apply. Maybe that is where your eyes are. or maybe your entire head. (sorry, could not resist).
    bryan3141
    bryan3141
    Reply 6 years ago
    And this is what comes of posting while tired. I apologize for my lack of reading skills and your lack of honor and manners.
    teshcreations
    teshcreations
    Reply 6 years ago
    Is that saying it's ok to make a copy for home use?
    Gamer4Fire
    Gamer4Fire
    Reply 6 years ago
    Yes.
    MichaelAtOz
    MichaelAtOz
    6 years ago
    and the cost of consumables was?
    Greasy fingers all over the Vinyl at 30s on the video...tsk tsk, probably explains the sound...
    Ehlers_TV
    Ehlers_TV
    6 years ago
    Awesome ! Thanks :-)
    hyperplane
    hyperplane
    6 years ago
    Did you notice an improvement of the sound quality of the original record?
    I think that the silicon cast may help to take all the impurities away.
    Istarian
    Istarian
    6 years ago
    Might be a way to have an acceptable backup copy of the record... I.e. if you can refine the process you can keep your vinyl and destroy the resin copy by playing. Have to wonder whether that would have any adverse effects on your record player though.
    Mike Rickenbacker
    Mike Rickenbacker
    Reply 6 years ago
    As someone that casts resin (models, sculpture, etc.) and loves records, I really don't think you'd want to play a resin copy too often, unless you're fine with replacing your needle more often than normal. Every resin I've worked with is *much* harder than vinyl and seems like it would wear out the needle faster or even break something so fragile. Not to mention the time and cost molding and casting would be way more than buying another copy of your favorite album :)
