Introduction: How to Plant a Perennial Garden
About: TN Nursery is a well-known online nursery based in Tennessee, United States. It specializes in selling a wide variety of plants, trees, shrubs, and other landscaping and gardening supplies. TN Nursery offers a…
Ever wanted to have your own flower garden? Something you'd be very proud of yet you don't know where to start or how? Well, We will show you the easy way how to prep. your soil, plant and grow the most beautiful flower and perennial bulbs.
The flowers that come from bulbs are among the most beautiful in the garden. They include daffodils, irises and tulips. Better yet, some come back year after year. Here’s how to plant them for the best results.
Step 1: Prepare Your Soil
The Soil
The soil should not be too wet or too sandy. Wet soil rots the flower bulb, and sandy soil doesn’t provide enough nutrients. The best soil for bulbs is loamy and well-drained. Plant the bulbs in full sun.
Step 2: Dig Your Hole to Plant
If a few flower or perennial bulbs are planted, the gardener can use a trowel, a dibber or a special tool for planting bulbs. If a lot of bulbs are going to be planted, they might want to dig a trench and plant many at once. Some gardeners who long for a more natural look toss bucketfuls of bulbs over the planting area, and plant them where they fall. This is also fun for kids.
Step 3: Know How Deep to Plant Your Bulbs
One caveat about digging a trench is that different size bulbs have different planting requirements. Since the rule of thumb is to plant a flower bulb three times as deep as it is long, bulbs will need to be planted at different depths. The depth is also determined by the type of soil. Bulbs are planted a bit less deeply in clay soils and more deeply in sandy soil. If the soil is amended with a lot of compost or other nutrients, the bulb should be planted deeper than usual. Another rule of three states that bulbs should be three bulb widths apart from each other. Bulbs grow best if they’re not crowded together.
Step 4: Fertilize Your Plants to Make Them Big and Pretty
Fertilizer for bulbs should be rich in phosphorus. Bags of fertilizer show the ratio of nitrogen, phosphorus and potassium in that order, so the gardener should buy fertilizer whose second number is higher than the first and the third. Toss the recommended amount of fertilizer into the hole, then cover it with soil so the fertilizer won’t burn the emerging roots. Gardeners can also fertilize the bulbs as they’re growing.
Step 5: ​Planting the Bulb
Master gardeners are always surprised at how many people plant bulbs upside down! The bulb should be planted with its basal plate down. The pointed end of the bulb should point up. The basal plate should have good contact with the soil to keep the roots from drying out when they emerge. If a gardener can’t tell which end is up, they should lay the bulb on its side.
Step 6: Cover the Bulb
Cover the bulb, firmly press down the soil, water, add more soil, and tamp it down again. Another tip is for the gardener to plant a flag or a marker at the spot to remind them of where they put the bulb. Markers made of non-rusting metal such as copper are good. They also add some needed nutrients to the soil.
Step 7: Perfect Planting Time
When to Plant For spring flowers, plant bulbs in the spring or the fall. Put the bulbs in the ground shortly after they are bought and before the ground freezes in fall or before the temperatures get above 50 degrees.Planting bulbs is fun and easy, and the reward is more than worth the effort.
