Introduction: How to Play Call of Duty Cold War Multiplayer on Xbox One
hello, do you want to learn the basics of call of duty cold war? it's easy once you get the hang of it
!!warning!! some bad language and violence in-game!
- Xbox
- copy of call of duty cold war
- headset(optional)
Step 1: Turn on Xbox
first, turn on the Xbox by tapping the circle button on the Xbox and it will turn white
Step 2: Open Call of Duty Cold War
using the ls go and select call of duty cold war by pressing A
Step 3: Load Game
wait for it to load when it show press a to start
Step 4: Go to Multiplayer
choose multiplayer and wait for it to load
Step 5: Go in to Game
select quick play click it again and wait for it to load
Step 6: Select Loadout
using LS select a loadout then choose it with A
Step 7: How to Move and Look Around
use LS to walk around and RS to look
Step 8: Jump and Crouch/prone
Press A to jump press B to crouch and hold B to go prone you can press A to get out of crouch/prone
Step 9: Shoot and Aim
press RT trigger to shoot hold the LT to aim
Step 10: Reload and Switch Guns
Press X to reload and Y to switch guns
Step 11: Use Tactical and Lethal Grenade
Press LB to throw your tactical press RB to throw lethal
Step 12: Use Field Upgrade
Press LB and RB at the same time to place your field upgrade
Step 13: Use Kill Streaks
right d-pad right to use kill streaks
Step 14: conclusion
I hope you learned something if you did leave a like❤.
