Introduction: How to Prep and Prime for a Flawless Makeup Application
To obtain a flawless makeup application, you must first start with your skin care routine. So this short tutorial is to help you with the products you need and in what order to apply those products.
Cetaphil Daily Face Cleanser
https://www.ulta.com/p/daily-facial-cleanser-pimprod2028661
Cetaphil Daily Scrub
https://www.ulta.com/p/extra-gentle-daily-scrub-xlsImpprod17762037
Thayers Witch Hazel Toner
Cetaphil Moisturizing Lotion
https://www.ulta.com/p/daily-facial-moisturizer-prod2045044
Babyskin Primer
Step 1:
For four out of the five steps you just need clean hands. So before you start clean your hands. After you finish wet your face, apply your cleanser in circular motions over your entire face for about two minutes. When finshed, rinse your face with cold water.
Step 2:
Apply your exfoliate to your damp face in circular motions also. Do this step also for about two minutes and rinse your face once done. Pat dry your face with clean towel.
Step 3:
After drying your face, apply a small amount of toner to a cotton ball and cover your face with it. Allow your face to air dry.
Step 4:
Once your face is dry from your toner, get a pea sized amount of moisturizer and apply it to your face.
Step 5:
Apply your primer after your moisturizer and then you are ready to begin your makeup application!
