Introduction: How to Project an IPhone Screen Onto a Macbook
Ever wondered if there was a way to project your screen on your phone onto your laptop? This instructable provides you with quick and easy steps in order for you to present a presentation or slideshow from your iPhone directly onto your computer. This is a hidden and beneficial feature when a TV or computer projector is not in the area and you'd like to present to a group of people with files saved on your phone. By the end of this tutorial you will become a master at screen mirroring slideshows on your phone onto your computer.
Disclaimer: Intended for educational purposes only. Tutorial may only be used with permission by contacting author at axellp@bgsu.edu
1. iPhone
2. Macbook
3. Lightning Charging Cord
4. Quicktime Player application (should already be pre-installed on newer MacBooks)
Step 1: Navigate to Your Home Screen
After powering on your laptop and signing in to your account, make your way into the home screen. Be sure to close out any additional applications or web pages that may be running in the background! In this tutorial I am using the current MacBook Air model.
Step 2: Connect the Lightning Charging Cord Into the USB Port
The lightning charging cord can be used for your MacBook by disconnecting it from the power brick. Once, you have done this you would want to locate the USB port on the side of your laptop and make sure it's plugged in firmly to your phone and into the computer.
Step 3: Open the Quicktime Player Application
Direct your mouse towards the application dock on the bottom side of your screen to open the Launchpad. Then, look for the Quicktime Player app which should already come installed with modern MacBooks and open the application
Step 4: Select 'New Movie Recording'
After opening the Quicktime Player application, your screen should look like the one above. Furthermore, move your mouse to the top of the screen and under the files menu, select the option of New Movie Recording. You can also access this by pressing Command Shift N.
Step 5: Under the Dropdown Menu, Select Your IPhone
Next to the sound bar, steer your mouse to the dropdown menu of the recording button and select the name of your phone. In my example, my phone's name is "Axell's iPhone" so I clicked on it.
Step 6: Select the Application You Wish to Present On
Almost there! Your iPhone's screen will appear on your laptop, but don't get too excited just yet, we aren't done. Now, select the application on your iPhone you have your presentation file on. For this tutorial, I am using the app called "Pages".
Step 7: Open the File You Wish to Present
Make sure you are using your iPhone to navigate and not your laptop. After opening the Pages app, I selected the file I'd like to present. For my example, the file is called "Professional Report".
Step 8: Tilt Your Phone Horizontally
For the best resolution, flip your phone horizontally and keep it connected to the lighting charging cord at all times during the presentation.
Step 9: Video Tutorial
An in-depth video tutorial of putting all the steps together!
