Introduction: How to Program Any Type of AVR Microcontroller With Arduino Ide || Hex Shield || Attiny85 || Atmega8 || Atmega32
About: i believe to help people and share my knowledge i always want to build creative thing some of them for learning and some of them is very useful.
Please subscribe to my YouTube channel.........
In this article we will learn how to program any type of avr microcontroller using arduino IDE via arduino.
I am explaining a concept to program any avr microcontroller with help of Attiny85 example.
By the way, subscribe to my YouTube channel for more projects like this. I also update my upcoming projects on Instagram.
buy me a coffee! ☕: Donate
Step 1: Arduino As ISP
  1. Take your arduino
  2. Connect with your pc.
  3. Open arduino IDE.
  4. Go in file >> example >> ArduinoISP
  5. Open ArduinoISP program.
  6. Select correct board and port in tools.
  7. Now upload the code.
Step 2: Program AVR Via Arduino Circuit
  • In the circuit the SCK,MISO,MOSI,RESET pins of AVR are respectively connected with 13,12,11,10 pin of arduino
Arduino's 13 pin -----------------> SCK of AVR
Arduino's 12 pin -----------------> MISO of AVR
Arduino's 11 pin -----------------> MOSI of AVR
Arduino's 10 pin -----------------> RESET of AVR
Arduino's +5v pin -----------------> VCC of AVR
Arduino's GND pin -----------------> GND of AVR
Step 3: ICSP Pinout of AVR
Here We are taking example of attiny85 but you can choose any AVR.
  1. Search "Attiny85 arduino pinout" in google.
  2. find the image same as given.
  3. find the ICSP pins, SCK,MISO,MOSI,RESET and VCC,GND
  4. Connect ICSP pins as shown in circuit.
Step 4: Find AVR Board Link for Arduino IDE
  1. Search "Program Attiny85 with arduino".
  2. Find the Board link in google results.
  3. Copy the the board link for attiny85 the link given below.
https://raw.githubusercontent.com/damellis/attiny/ide-1.6.x-boards-manager/package_damellis_attiny_index.json
  1. Go to the arduino IDE.
  2. Click on File -> Preferences
  3. Paste the link in Boards Manager URLs. if there is other links, then paste link after comma ",".
Step 5: Install the AVR Board for Arduino IDE
  1. Go the Board manager via "Tools >> Board >> Board manager"
  2. Here search "Attiny85".
  3. You will get a Library install it.
Step 6: Upload Bootloader in AVR and Upload Program in AVR
  1. Open the code which you want to upload in AVR or you an download the code from github page given below.
  2. Select Attiny category in board.
  3. Select processor as attiny85.
  4. Select clock as internal 8Mhz.
  5. Select programmer "Arduino as isp".
  6. Click on upload bootloader.
  7. After bootloader uploaded go to the sketch.
  8. Go to the sketch >> Upload using programmer.
  9. The code will be uploaded successfully.
github link : - https://github.com/vishalsoniindia/Program_AVR_fro...
Step 7: Connect Circuit As Program
if you uploaded my code then you can connect circuit as shown.
  1. Push button is connected to 2nd pin of AVR
  2. Two leds is connected at 3rd and 4th pin of AVR.
Step 8: Done
  1. Now you can see the Push button turn on led Alternatively.
Step 9: Hex Shield
  • If you don't want to mess with wires then you can use the hex shield.
  • The Gerber file and schematic is given below on github link .
  • The shield many type of controller all are written on the shield.
  • if any AVR is out of this list then you can program it via ICSP pins on shield.
  • the shield has crystal selection jumper for 8Mhz and 16Mhz.
Github :- https://github.com/vishalsoniindia/Program_AVR_fro...
Step 10: Order PCB
  1. This PCB is sent by PCBway you can order high quality PCB from PCBway.
  2. Link to order PCB :- https://www.pcbway.com/
