Introduction: How to Properly Apply a Gait Belt
NOTE: THIS PRODUCT IS NOT INTENDED FOR USE AS A RESTRAINT.
REMOVE AFTER EACH USE
WARNING: Inspect before each use. Check for broken stitches, parts, or buckles that are cracked or broken and do not hold securely. Before using, ensure the patient can safely wear a gait belt. A gait belt is designed to assist a patient and caregiver in ambulatory care and prevent falls. Below are step-by-step instructions for proper use.
Gait belt of your facilities choosing
Step 1: Greeting
Greet the patient to let them know what you are going to do.
Step 2: Position
Position patient with feet flat on the floor.
Step 3: Place
Place the belt around the patient's waist, just above the hips, over clothing but not any tubes or wires.
Step 4: Adjust
Adjust the belt to ensure a sung proper fit by gently holding the middle of the belt while pulling the excess belt.
Step 5: Lay
Lay your hand flat between the patient and the belt to ensure a comfortable fit.
**You should be able to slide your open hand (flat) between the belt and the patient to ensure proper fit.
Step 6: Tuck
Tuck excess belt through the waistband, the flap should lay flat across the buckle.
