Introduction: How to Properly Install a Wig
I installed a wig on my daughter this method is quick and you will be done in less than an hour.
wig cap, got2b spray, color matching make up (light and dark) ,lace front wig, hair band , eye brow razor, and hair glue.
Step 1: Braid Down
braid the hair down into a crown after it had been washed and blow dried.
make sure the forehead has no residue or build up , it can be cleaned with an alcohol pad or rubbing alcohol.
put on a wig cap
Step 2: Trying on the Wig
try the wig on and get any sort of makeup and place marks so you know where to glue when it is time.
Step 3: Cut the Wig
cut the lace that comes on the wig into thirds (sections)
Step 4: Glue
dot the glue along the top line of your bald cap just a little bit , do not go overboard with it or it will come out wrong. continue doing this around the whole head three to five times, it has to be dry and clear, if it's white it will not work.spread the glue in , not to far ,also continue this around your whole head.grab one section and place it above the glue , this is very important
Step 5: Band for 30 Minutes
place the band across the hairline TIGHLY for around 30 minutes to one hour.
Step 6: Cutting Excess Lace
after removing the band, use scissors or a eyebrow razor and cut the excess lace that isn't glued down in a zigzag motion.
Step 7: Matching the Color of Lace
Put a darker shade of makeup from your skin color on the parts that look uncolored, not too much or it will not look good.
Step 8: Spray
Put got2b spray on your finger and tap the lace with it .
Step 9: Band
you will now put the band on because if not it will lift the wig up . wait 30 minutes , then you can style the wig at this time. wait 30 minutes and then you can take it off and enjoy.
