Introduction: How to Recycle a Coconut Shell Into a Bowl
This is my (very similar) take on goldenbacon's coconut bowl tutorial, the main differences being that I used waterproofing lacquer I made myself rather than a spray-on waterproofer, and that I went into far more detail about each of the steps. I also adapted a trick for getting the meat out of the coconut more easily.
This project was completed for an art class, but I hope everybody can get some use out of it!
Here is a list of the materials you will need::
For the bowl itself:
- one coconut
Tools:
- hammer
- hack saw
- box knife (or other sharp blade)
- chisel or spoon
- a substantial black marker
- a thick nail
- one sheet of sandpaper
- a bowl or jar
-a small (1 1/2 inch) paintbrush
For the finish/waterproofing:
- linseed oil
- mineral spirits
Step 1: Drain Your Coconut.
The first task will be to punch a hole through the outside of the coconut to drain the fluid from inside of it. Initially, I tried to hammer the nail directly into the top of the coconut, where it had joined to its stem. As far as I can tell, this is impossible. Instead, I recommend placing the nail slightly to the side of the top of the coconut, where the shell is less dense. Depending on the width of the nail, the initial hole might not be large enough to drain more than a trickle of fluid; I ended up making three holes close to one another, and then breaking down the shell in between to create one large hole.
Once you've made a hole, place the coconut, drainage hole down, over a container whose mouth should be smaller than the circumfrence of the coconut. You can leave it to drain on its own, but I recommend shaking it from time to time to move the process along. You will know the coconut is completely drained when fluid stops trickling out, and when the coconut no longer makes a sloshing noise when you shake it.
Step 2: Mark and Cut the Coconut.
The next step is to draw a line with your marker around the circumfrence of the coconut, either dividing it in half or at whatever proportions you prefer your bowl to be. Remember that the half with the hole in it will be unusable as a bowl, and should probably be the more shallow of the two halves. To get an even line, I recommend standing a ruler on its end, with the coconut on a flat surface, and making a series of marks at the same height, then connecting these with a solid line.
When sawing along the guideline you've marked, I find the most effective way to get an even cut is not to saw all the way around the shell, but to pick one spot and work in deeper from there. My saw was fairly dull, so it worked much better to cut a narrow groove and then saw straight through from that point, using the guideline to keep the saw even. This step should take about ten or fifteen minutes, depending on how strong you are (and how sharp your saw is).
Step 3: Hollow Out the Coconut.
Once you have the two halves separated, a good trick I read for loosening up the meat of the coconut for removal is to pop the bowl-half into the microwave. Two minutes should be sufficient; it will be quite hot when you take it out, so use caution, and give it a few minutes to cool down again before proceeding to the next step.
To remove the meat, the original tutorial I found suggested the use of a chisel, but I found that after microwaving, a spoon worked equally well. The way to accomplish this is to score across the diameter of the fruit with your box knife, creating pie slice-shaped sections. You can then wedge the tip of your spoon between these and the shell of the nut, and pry them loose in more or less whole chunks. Ideally, the membrane between the meat and the shell will come off with them, leaving the inside of the shell bare; it should have a rough texture and look like tightly-packed plant matter.
Step 4: Sand Out the Shell.
To finish off the texture and prepare the bowl for lacquering/waterproofing, take a 6x7 rough-grain sheet of sandpaper and tear it into quarters, then fold one of these smaller sheets double. Sand down the inside of the bowl until it feels smooth and there are no loose bits of coconut "hair" when you run your fingers over the inside. Do similarly with the outside, which will take more time and require a second sheet of sandpaper, since there is a lot more "fuzz" to remove. I would suggest also sanding down the rim of your bowl, since you might want to drink from it later!
Step 5: Waterproofing/lacquering.
This step is optional, depending on whether your bowl is intended to be decorative or functional, but in either case I think the lacquering step makes it look much nicer and has a similar effect to "staining" the wood. Here you will mix one part linseed oil with two parts mineral spirits. One cup of the solution should be several times the amount you'll need; I was doing this by ear and ended up making much more than was ultimately necessary. You should be able to get by even with just a third of a cup.
Using a 1 ½-inch paintbrush, coat the entirety of the inside and outside of the bowl with the linseed oil solution. For full waterproofing, I would suggest five or six coats, possibly more. Drying time for each coat could take anywhere from half an hour to two hours, depending on humidity; I used a hair dryer to speed the process up, to no ill effects. Each coat should be applied once the previous one has dried.
10 Comments
Tip 3 years ago on Step 1
At one end of a coconut shell, we can find its 2 eyes and a mouth..Piercing at this site makes the above step much easier..
Tip 4 years ago on Step 1
You could also just cut it in half directly, but once you are through the outer layer, drain it. You may get some husk in the coconut milk, but you can filter that back out with cheesecloth if you want to drink it. This way, you get two bowls from each coconut.
I just need some coconut shelters for my aquarium, so holes won't matter.
5 years ago
I microwaved a beautifully cut and sanded coconut shell, like your recommendation, to easily remove the meat. But one minute in the shell decides to crack :/
10 years ago on Introduction
Great instructable - the finished coconut looks terrific!
However before you go full Gilligan I urge you to consider a food-safe finish. "Boiled" linseed oil contains various drying chemicals that you definitely do not want to drink. Likewise I would never put mineral spirits into anything that I ever planned to eat or drink from.
Some food safe finishes include Beeswax, Mineral Oil, Walnut Oil, pure Tung Oil, raw Linseed oil, and Shellac. For the latter three you'll want to buy only the pure product, food grade and without additional chemicals - these can be hard to find but will be available from specialty woodworking shops, etc. The products that you'll find at your local hardware store will almost certainly not be something that you would want anywhere near your food.
Reply 6 years ago
Full Gilligan.....LOL
9 years ago on Introduction
does coconut oil work?
9 years ago on Step 6
Nice looking project. One comment on oldorf's note.. Olive oil will turn rancid with time. I make wooden bowls, spoons, cutting boards, etc, and treat them with mineral oil. Use USP grade from the pharmacy. It is harmless, never spoils, and is easily recoated when it wears off. If the coconut shell is substantially nonporous, any of the common clear finishes will be fine. They are all food safe after they have cured - usually a week or so.
yes i know !!!!!!!!!!!!!!!!!!!
10 years ago on Step 6
Well done - but poor coconut - you butchered it. I have got some ideas how to rescue the juice and meat. Every Coconut has three eyes on one of the ends - one of them is realy soft - so test them and poke a nail without much force through the weakest one. This will allow you to drain it completely. If the nut was fresh and has a lot of juice/milk, you can drink it - it is delicious.
The meat is a delicacy, so it should not be wasted or destroyed. SInce you need an intact half of the nut you can not use the easy method of opening it with a hammer. So use a clean saw. Once you have opened the nut take your time and cut the meet with a knife - then use a strong spoon to force it out of the shell. Skip the microwave unless you want cooked coconut meat. Wash the meat under running water and sample it...
If you have a disc sander you can trim the rim of the shell nicely with it. For a food safe finish I would entirely rely on Olive Oil - which makes it look and smell nice.
The finished bowl looks amazing. Great tutorial. :)
