How to Reduce Video Size [ Up to 90%]
Intro: How to Reduce Video Size [ Up to 90%]
How to reduce video size [ up to 90%]
STEP 1:
go to handbrake.fr click here.
STEP 2:
download and install software.
STEP 3:
import file which you want to convert.
STEP 4:
select from available presets if you are beginner.or if you know about handbrake then you can do it manually.
STEP 5:
select your video format mp4 or mkv.
STEP 6:
select web optimized if you want to send video via the internet or want to upload video to youtube.
STEP 7:
from video section if selected cropping automatic and values are not 0 then it will crop your video so change it to custom and set that values to 0.
STEP 8:
select video codec as per your requirement.
* h.264 is recommended.
STEP 9:
set your video quality. 20 to 23 is better.set it as your requirement.
STEP 10:
from audio section set the bit rate to 128 kbps.
STEP 11:
- subtitles and chapters are not that much important.
- previewing your video quality is better because video compression takes lots of time and if that quality is not as per your requirement then it is waste of time so let’s see how to watch your video preview.
- select preview and set your preview duration and select preview.
- After previewing your video click on start encode.
Swansong 6 years ago
Thanks for sharing :)
