Introduction: How to Remove Rust From Garden Tools!!!
This is just a simple way to remove rust from tools.
Some needle nose pliers a can of WD40 a cup or so of vinegar and a sanding block.
Step 1: Vinegar
First you want to put them in a cup of vinegar and let them soak for maybe 12 hours?
Step 2: Soaking
Then I took them apart and let them soak in WD40 for a while.
Step 3: Sanding
I sanded the blade part with the block. After that I used the needle files and got the little nooks and crannies.
Step 4: Oiling
So you’ll need some olive oil and you just want to soak a cloth and then rub down the blade.
Step 5: Thoughts
I probably should have soaked it in vinegar longer and sanded I bit more it works
