Introduction: How to Remove an Intel CPU Fan
In this inscrutable I will show you How to Remove an Intel CPU Fan.
What you will need:
· Paper/Kitchen towels
· Cotton swabs
· Rubbing alcohol (90% or higher)
· CPU thermal paste
Before you start:
· Shut down the computer.
· Unplug all of the cables from the back of the computer.
· Take proper electrostatic discharge (esd) precautions.
Step 1: How to Remove an Intel CPU Fan
Remove the fan connector from the fan header.
Step 2:
Turn the push pins with fingers or a flat screwdriver counterclockwise 90 degrees to release them.
Step 3:
Pull up the push pins.
Step 4:
Remove the fan.
Step 5: How to Apply Thermal Paste
you should replace the thermal paste if you remove your cooler for any reason.
Step 6:
Dip a soft cloth or tissue in the isopropyl alcohol and gently remove the previously applied thermal paste. Wait for a while until the alcohol dry before installation.
Step 7:
Inject the thermal paste from the syringe to the center of the processor
Note : Always replace the thermal paste. Never add new thermal paste on top of used thermal paste.
Step 8: How to Install an Intel CPU Fan
Turn the push pins clockwise 90 degrees to reset them.
Step 9:
Reinsert the fan.
Step 10:
Press the push pins in the order shown to secure them.
Step 11:
Plug the fan connector from the fan header.
Step 12:
you can watch below video for further clarification.
