Introduction: How to Repair Busted Headphones
Have you ever had that $200 pair of headphones and your beloved happy dog chewing the cable?
Here I will show you how to repair the cable of your badly damaged headphones and basically give them another chance!
Or if you wish to do like me and save yourself $150 by buying busted headphones from ebay for about $20 and then fixing them like a pro!
(This instructable is very similar to another that I've posted, but this is in more detail and shows the whole headphones repair. )
Step 1: Tools and Bits Needed
This will keep the joints tough as well as flexible!
You may need:
- Cable cutters
- Knife
- Clamp
Step 2: Cut Bad Sections
Step 3: Prepare Wires for Soldering
Strip the cable and remove the insulation shield around the individual wires. This is easy to do with a lighter.
Then apply the solder to the ends.
Step 4: Connect
When soldering together the wires, make sure they are insulated.
I used some heat shrink tubing for the insulation.
Step 5: Fixing the Jack
The cable connector was in a bad condition. This could look like it is OK and still not work properly. If you can hear through one of the headphones only or the sound is intermittent, then it is the connector that needs to be fixed.
Step 6: Extract the Metal Tip
We need the metal tip of the cable so all the rest goes to the bin.
This is where attention needs to be paid to remember which wire goes where.
Step 7: Reconnect the Cable
Solder the wires to their places on the connector.
Keep the wires short and as tidy as possible.
Step 8: Seal the Joints With Polyurethane Silicone
Using something as a spatula, apply some silicone on the soldered joints. Leave for about 24 to 48 hours to let the silicone cure.
Use polyurethane silicone! This will ensure that the rubber stays soft and flexible. There may be other types of suitable silicones, but I do not know, you have to tell me.
If you enjoyed, please vote for me in the Soundhack and FIX IT contests!
Runner Up in the
DIY Soundhack Contest
Third Prize in the
Pocket Sized Electronics
First Prize in the
Fix It Contest
Epilog Challenge V
76 Comments
Question 2 years ago
Good idea, but how did you enter this instructable in multiple contests?
If I try, it says an instructable can only be in one contest.
Question 3 years ago
What about both ear buds? The farret! Chewed the off. They were literally 1 week old:-(
5 years ago
my cat broke my earbuds and no sound and she broke an the wire is breaking if i pull it it will brake and i need to fix cause my brothers girlfriend bought them for 20$ please help me
5 years ago
What happens if you do not know how to repair it yourself? Can i take it to a store? my wire stretched on one side and does not work can it be fixed?
6 years ago
I usually use hot-melt and heat gun for quick curing.
Apply hot-melt and blow it with heat gun to make even surface.
If you touch up with wet finger, you can have better visual.
You could substitute the heat gun with a gas lighter or cooking range
Reply 6 years ago
Sure, that would work! Only disadvantage is that the resulting glue blob won't be flexible as the silicone is.
Reply 6 years ago
In other words, the movement of elastic silicon could force the solder joints apart easily what means shorter life time.
Reply 6 years ago
Sure, I didn't think about that!
6 years ago
Nice, just the instructable that I was looking for, but, we should not have to "remember the connections" isn't there an industry standard pin out for head phones/ head phones with a mic. Can anyone point me to it?
Reply 6 years ago
For the "3.5mm 4 pin terminal microphone/earphone" pin-out guide, refer to:
http://pinoutsguide.com/HeadsetsHeadphones/samsung_moment_pinout.shtml
Reply 6 years ago
There are standards - one for Apple obviously and one for everybody else including Android devices. Remembering the connections would make it easier when you have to locate the 2 speakers in the ear buds and the microphone cable +ve and GND.
Make a google search with "audio jack apple and android connections" - I think Apple has the GND and MIC rings swapped to the others
6 years ago
Just go to the Dollar Store and buy new ones.
https://www.dollartree.com/household/electronics/S...
Reply 6 years ago
Right, because they will sound the same after this repair.
Reply 6 years ago
Do you know what dollar store head phones sound like? I'll tell you then- SH*T!
6 years ago
This is so awesome! You would not believe how many headphones we've gone through, for iPods, computers and gaming systems! I will definitely be trying this before even thinking of replacing them again. Thanks!
Reply 6 years ago
Always glad to help!
6 years ago
Oh, I'm sending this to my daughter - she's got so many pairs of earphones lying all over the place, broken or soon to be!
Reply 6 years ago
I'm glad you found it useful! :)
6 years ago
can you use a different jack from another pair of headphones if the jack is the problem?
Reply 6 years ago
of course you can. u just have to figure out which is the cable for ground left right and microphone. guide through this picture
http://cdn3.howtogeek.com/wp-content/uploads/2014/...
(IF you find this is not working swap ground/common, with microphone)
