How to Repair Plastic Bumper Scratches
Intro: How to Repair Plastic Bumper Scratches
Is your car bumper scuffed or scratched? While not as severe as a crack or dent a trip to a repair shop not only costs quite a bit, but they will probably need to keep your car for a day or two.
So why not fix it yourself?
In this instructable we are going to show you how to repair a scratched plastic or fiberglass bumper cover on your own, in a fraction of the time, and at a fraction of the cost.
What you need:
What you need:
- Factory-matched paint in a spray can
- Automotive spray primer
- Automotive spray clear coat
- Some sheets of coarse and fine sandpaper
- Scuff pad
- Cleaning towel
- Wax and grease remover
- Scratch-filling putty
STEP 1: Apply Masking Tape
Mask off areas around the damaged area that you do not want to be hit by spray paint.
STEP 2: Sand Bumper
Using firm pressure, sand the damaged area of the bumper until you have smoothed the scratches out.
STEP 3: Clean Panel
Wipe down the panel with a cleaning towel, then clean the entire area with wax and grease remover.
STEP 4: Fill Scratches
If you find any scratches that will not sand out, fill them with a thin layer of scratch-filling putty.
Give the putty five minutes for it to harden, then sand it using some coarse sandpaper.
You might need to repeat this step again in order to smooth everything out.
STEP 5: Scuff Repair Area
Using a grey scuff pad, scuff about 10 inches around the repair area.
This will help the paint stick and be more durable over time.
STEP 6: Prime Bumper
Apply a thin layer of primer, wait two minutes, then apply a heavier layer of primer until you have covered any areas exposed by sanding.
STEP 7: Paint Bumper
Sand the primer using fine-grit sandpaper with light pressure until it feels smooth.
Apply multiple coats of paint from a distance of about 10-12 inches.
If you encounter any bumps, cloudiness, or what looks like "cat" scratches wait five minutes, sand again, and re-apply paint.
If you car is silver or gold and you notice stripes, following up with some vertical passes.
STEP 8: Clearcoat Layer
Give the paint five minutes to dry, then apply a light layer of clearcoat.
Wait two minutes and slowly apply a heavier layer, overlapping each pass by around 50%.
Give the clearcoat 10 minutes to dry before removing the tape and paper.
14 Comments
richarpo 3 years ago
JamesP146 8 years ago
Is there do you know any any easier way is there like a chemical scratch remover could spray on or something like that and and buff wipe it in and then let it dry and wipe it back off and then wax it or something. I heard of something like that but can't remember where
Cf
JohnD637 6 years ago
Sounds like someone having a laugh, there is no such product available for scratch removal, no magic sprays to remove scratched paintwork, its a process of sanding filling and sanding, and polishing that's the only way you will get a professional finish
appliedcolors 8 years ago
I would not recommend using putty as it does not harden properly, best to use thin layers of body filler, also you will need 240 - 320 - 1000 grit wet and dry sanding paper, and scotchbrite pads to get the correct finish, plenty of videos on you tube of how to do this correctly
marcpilot1 6 years ago
what brand of putty type stuff did you use in step 4? (fill scratches) Ex instructable btw!
RonaldL46 7 years ago
What type of sand paper for Step 2? There's different kinds?
MandiS8 8 years ago
Params3 8 years ago
how long are these steps will taken upto finish.?
ksvivek 8 years ago
These steps look doable and the details look complete. I will give it a try on my 2007 Audi A4 and post the results when done.
HelenJ1 9 years ago
Thank you very much for an easy to follow guide.
appliedcolors 10 years ago
artwell 10 years ago
Straightforward. Nicely done.
srd007 10 years ago
