Introduction: How to Repair the Automatic Electric Kettle When It Is Broken
Many people may not care about small appliances. If the electric kettle at home is broken, basically you can only replace it with a new one. If you know something about electricity, you may wish to consider checking the cause of the electric kettle and try to repair it. , If it is repaired, the resources can be regenerated. The following is an example of an electric kettle that is plugged in without any problems with the socket and wires from the outside, and the automatic electric kettle is broken! This I bought this MOOSOO electric kettle 5 years ago. The quality is good and it is not expensive. It cost me 65.99 dollars. I have used it for too long and it is out of order. I like this MOOSOO kettle very much and I don’t want to replace it with a new one.
Step 1: MOOSOO Electric Gooseneck Kettle
1. This is the electric kettle that is plugged into the socket without any problems from the outside without any problems with the socket and wire as mentioned above.
Step 2: Handle Screws
Then you need to observe all the screws on the electric kettle carefully one by one, and then slowly remove them. It is best to find a container to install the screws to avoid losing them.
Step 3: Disassemble the Kettle
After taking apart the electric kettle without clothes.
Step 4: Find Fuse
Look for it along the power cord, you will definitely find it, like the fuse of this pot treasure hidden in a place that a ghost can see
Step 5: Where Is the Fuse
Sure enough, the fuse is wrapped in a mysterious white envelope
Step 6: What the Fuse Looks Like
The red line in the figure below is the fuse
Step 7: What to Do With Fuses
Then you can cut the fuse first without saying a word, and then connect both ends of the wire with wire tape
Step 8: Plug in
At this time, don’t be afraid to take the electric kettle and plug it in. The power light is on, and then check whether the heating element is heating up. If there is any, then the fuse is broken. Go to the water and electricity store to buy a new one. After the wire and tape are connected, the electric kettle is resurrected!
