Introduction: How to Replace Horizontal Sliding Windows
About: I am a Blogger and an Author. Loves to Write!
Replacing old sliding windows with new windows is important if the former solutions have ceased to provide the benefits that you want. Installing sliding windows can be done on one’s own by following a few steps.
It is possible to replace the existing sliding windows without completely ripping off the exiting window frame from its place. This obviously makes the entire process of installation much easier. Also, the time taken to complete the task significantly decreases. There can be many reasons why one would want to replace old windows with new ones. The most obvious signs usually include drafts blowing the drapes, water damage is clearly evident, and frost forming during winters. Replacing old drafty or aged sliding windows therefore will improve your home’s appearance and make it more energy efficient.
Given below are the steps involved in the replacement process.
Step 1: Pull the Window
Begin by pulling the window top towards you until it is out of the sliding track. Then pull up the window bottom. With the help of a screwdriver, force out the window stop from the sliding track of the frame.
Step 2: Remove the Fixed Panel Bar
Proceed to remove the vertically fixed panel bar. If it is held in place with a screw, then remove it. With the help of a hammer, loosen the affixed panel bar from the panel in the frame and gently pull it out.
Step 3: Measure Your Window
As the next step, proceed to take measurements of your entire window opening. From the window sill, measure the entire height to the bottom most point of your window frame sliding channels. This is the height of the wooden support strip. Now measure your new window’s bottom frame that will extend beyond the existing frame channel to the sill. This will give you the width of the wooden support strip. Measuring the length of the sill will give you the length of the support strip.
Step 4: Provide the Support Strip
Use the measurements taken and transfer them a two-by-four to get a new support strip. The purpose of this strip is to support the sliding window sill by fitting into the interior sill. Nail the strip to the interior sill. Apply an even coat of silicone sealant all around the existing window frame.
Step 5: Replace the New Window Frame
From the outside, tilt the sliding window bottom frame into the existing window frame. Make sure it is centered on the opening from the inside. Check for equal-sized gaps around the window. Place the window frame top in place against the exterior.
Step 6: Screw-up the Frame
On the left and right sides of the frame, drill two holes on the interior sliding window channel. Then screw-fix the window and make sure it has been secured in place.
Step 7: Check for Unevenness Around Corners
Do an inspection of the window for gaps or unevenness of area around the window frame. Position the window with screws.
Step 8: That's It! You Have Replaced Your Horizontal Sliding Window
If you can handle the horizontal sliding windows installation on your own, well and good. But in case you are unsure of taking it up as a do-it-yourself challenge, then it would be wiser to seek the help of a professional contractor.
Do you have single track or multi track sliding windows in your home? If you desire to check latest 2 track, 3 track or 4 track sliding windows, get them online! And also tell us why you like them by leaving a comment below.
