Introduction: How to Replace a Steering Rack
It’s a crisp morning as you carefully back your car down the driveway. A quick turn of the wheel as the front tire clears the curb
will swing your car up
the street. But the steering wheel is strangely stiff. Instead of swinging the
car’s nose around, you run straight back, knocking over a trash can across the
street. Fortunately, the damage is small:
a crunched $14.95 rubbish barrel and a slimy mess to pick up in your
second-best suit.
“What happened?” you
wonder
as you pop the hood.
“The belt’s still there and the fluid’s up—although it does look black. Maybe the belt just slips until it warms up.” After tidying up across the street and tidying up yourself, you try backing out again—with both hands on the wheel. The steering feels fine now—no groans and plenty of power steering boost. If the belt is 4 years old or more, go ahead and change it because it’s due anyway.
But don’t be shocked if the problem returns the next chilly morning. Power steering that awakens slowly on cool days has so-called “morning sickness.” It won’t go away. It’s caused by wear inside the steering assembly (aka the “rack”). The fluid’s black, metallic look is a result of metal worn from the inside of the housing. The fluid is abrasive, and the wear will worsen with time. The rack is shot—replace it and use the opportunity to flush the junk from the pump and lines.
Step 1: Can I Do It?
Swapping a rack is simple in some cars, nasty in others. For example, a rear-drive car’s rack, if bolted in front of the front
crossmember, is usually easy to change. But it’s more challenging in a front-driver with the rack bolted
to the subframe behind the powertrain or against the firewall.
Should you do it yourself? A shop manual may tell you how
tough the job will be, but not always. One
General Motors manual says you have to lower the front subframe
3 in. to get enough clearance to slip out the rack. Maybe, maybe not. Legions
of technicians just twist and wiggle it through the existing space with no
problem.
But you should still check the service manual. For one thing, it’ll let you know if there are nuts and bolts that must be replaced with new ones, for safety’s sake, when changing the rack. You will also want to know the torque values for all fasteners. Are there any O-rings involved? They’ll need replacing. The manual will tell you. Before chickening out, look at a replacement rack. You’ll see the location of bolt holes and the fluid pressure and return line ports—the only fluid lines you’ll need to disconnect and reattach at the rack. Safely support the car and check clearances.
If you find you can’t grasp everything you need to work on from under the car or by reaching around the engine, you may opt to send the job out. Lastly, before deciding, talk with people who know the job, such as the front-end pro who’ll align the car after you’ve swapped the rack, or a dismantler at a local salvage yard. They may know legitimate shortcuts.
Step 2: Doing It
Ready to go? It will help if you remove the front wheels for better
access to the wheel wells. Break
all the lug nuts free before using
the jack. Lift the car and support it safely on stands. Then, unbolt the clamp
that connects the steering column to the pinion shaft.
Detach the outer tie rod ends. You may need to use a special
tie rod end puller to get the tapered bolt
to relinquish its grip on the steering upright.
If you’re reusing the old outer tie rod ends, don’t take them off the knuckles with a fork-type remover—it’ll wreck the grease seals. Use a puller-type remover. Better yet, you probably can leave them in the uprights. Just loosen the jam nuts and turn the tie rods with a pipe wrench. The rods will unscrew from the ends—clockwise on one side, counterclockwise on the other. Unbolt the rack from the chassis. Now you can disconnect the fluid lines and capture the power steering hydraulic fluid as it drains.
Step 3: Flushing
In spite of having digested considerable amounts of crud, many
power steering pumps survive morning sickness intact. Still, you’ll need to
remove contamination to preserve the new rack. Here’s how to flush most of the
junk out of the pump and lines.
Disconnect the return line
to the fluid tank and let it drain into a small container through the return
hose. This is the low-pressure side, usually secured with a hose clamp. Then
block the hole. Vinyl vacuum caps work well.
Next, disconnect the pressure line from the rack and aim it
into a bucket. Refill with fresh fluid and tap the starter—it will pump quickly
and may take a quart or more to clean the line. Cap or plug any loose ends.
Now it’s time to twist, wiggle and snake the old rack out of the vehicle. Expel any minors from the garage, as they may find the language necessary to persuade the rack clear of the vehicle unacceptable.You may need to unbolt and slightly move some other components to get the rack out of its tunnel. Lift, twist and wiggle in the new rack and reconnect the fluid lines. It may be easier to get a wrench to swing on a fluid line attachment once you’ve unbolted the rack and moved it a bit. Also, reattaching the lines may be easier before the new rack is bolted in place. Use a tape measure to check the overall length of the rack and tie rod assembly.
Set the overall length of the new assembly to this same dimension by twisting the tie rod ends on their threads. Keep the rack centered and split the overlap difference between the left and right rod ends as you do this, or the steering wheel will be off-center when you’re done. Connect all the lines, the steering shaft and the rack-attachment hardware. Use fresh cotter pins in the tie rod ends’ castellated nuts.
Reattach the front wheels. Once the new rack’s in, reconnect all hoses except the reservoir return line. Point it into a bucket, then refill. Start the car, and run fluid through until it looks clean. Reattach the pressure line. Note: You may be able to install an aftermarket inline filter so any crud you miss won’t harm the new rack. Have an alignment shop reset the toe-in adjustment or the car may handle strangely and wear out its tires rapidly.
Step 4: The Fluid Situation
The last step is bleeding out all of the trapped air. While the car’s still
elevated on stands, fill the reservoir, idle the engine and steer side to side,
from lock to lock, 10 to 12 times. Be careful to avoid banging into the stops.
Tan or foamy fluid contains
air. Shut down, let it sit 15 minutes, then top off and start again. Repeat
until the fluid looks normal. (This procedure is covered in more detail in Auto
Clinic, Dec. 2001, page 111.)
Don’t forget to properly torque the lug nuts on the front
wheels
after you’ve taken the vehicle off the jackstands. And it wouldn't be a bad idea to change the power steering fluid in a few hundred miles to get out any crud you missed.
