How to Replace a Toilet (Step-by-Step)
Introduction: How to Replace a Toilet (Step-by-Step)
About: We love home improvement and enjoy sharing tips on YouTube and Home Repair Tutor. Everything we do is self taught. Over the last 12 years we've bought and rehabbed several rental homes in Pittsburgh. Sometim…
Today you'll learn how to replace a toilet.
This is a good skill because it'll save you at least $200. Plus, you'll see tips to prevent every homeowner's worst fear: NASTY toilet water leaks!!!!!! I've seen this happen and it gives me the willies every time. Fortunately replacing a toilet isn't hard and anybody can do it. Whether you're a new homeowner or experienced one I promise you'll get great tips today. We'll be installing American Standard's VorMax because it has new technology that cleans the bowl every time it's flushed.
The VorMax's cleaning technology made it a no brainer for this rental.
You and I both know that cleaning a toilet is easy but often a forgotten art. And if simply flushing the toilet helps keep it looking good...that's awesome. American Standard sent me the VorMax to test but I've been using their toilets for years. When I find great products I love sharing them with you. That way you can have the same great experience as me. Here's your supply list
  • Toilet (e.g. the VorMax)
  • Steel Braided Supply Line
  • Quarter Turn Ball Valve (Optional - Compression Fitting)
  • Quarter Turn Ball Valve (Optional - SharkBite Fitting)
  • Crescent Wrench
  • Shims (Optional)
  • Torpedo Level
  • Screwdriver
That's not a bad supply list.
You'll see that most of what you need actually comes with the toilet...well at least in this example. How should you start the process of swapping out an old toilet for a new one?
Step 1: How to Choose a New Toilet
What are some things you should consider when shopping for a new toilet
  1. Rough-in
  2. Height
  3. Shape
  4. Color
  5. New Technologies
The rough-in is the measurement from your existing closet flange bolts to the wall (not the baseboard).
This dimension is typically 12 inches but double check and save yourself a Homer Simpson 'Dolt' moment.
Next, I know this sounds weird but I'm gonna say it anyway: sit on the toilet at the store before you buy it. This ensures the toilet feels comfortable before you install it. The VorMax in today's tutorial is 30 13/16 inches high.
The last thing you want is for the toilet to be uncomfortable when using it.
Thirdly, toilet shape can affect the feel of your bathroom. If your space is limited you might want a round toilet bowl. But if you have a larger bathroom the elongated style could be better. I wanted a round bowl for the bathroom in today's video. But frankly having a toilet bowl that helps clean itself trumped the shape thing. You'll see that the elongated label is on the VorMax box.
My fourth tip is to pick a toilet color that matches your room's decor. I chose white because it's a classic look and won't go out of style any time soon. Plus, white matches the other items in the bathroom.
Finally, toilets these days have a lot of bells and whistles. The VorMax, in addition to cleaning itself on every flush, has EverClean technology and a Slow Close seat.
The EverClean coating helps inhibit the growth of stain/odor-causing bacteria, mold & mildew. This is great for anyone who hates cleaning toilets (it's not my favorite pastime).
Okay, now that you have the toilet picked out what's the next step??
Step 2: Inspect Your Toilet's Closet Flange
Twelve years ago my wife and I bought our first rental property. It's a cozy house that we picked up for $17,000. Hey what can I say, Pittsburgh has affordable homes.
The folks we hired to remodel the bathroom weren't exactly great contractors. And as a result we ended up having several issues.
One of which was a toilet leak down into the dining room. DISGUSTING. But the good news was our plumber Charlie fixed it and we never saw a leak from then on!! What tips did Charlie share? The biggest culprit when it comes to toilet bowl leaks is the closet flange.
The flange should be at least even with the finished floor. It's preferable to have the flange resting on top of the tile. But what if you can't move the flange?
No problem. Check out my tutorial on how to repair a toilet flange and you'll see how to solve this issue for under $30. Once the toilet flange is good to go you can start the toilet installation.
Step 3: Setting the New Toilet Bowl on a Wax Ring
This next tip has nothing, well almost nothing, to do with your toilet bowl.
If you're replacing the toilet you should inspect the shut off valve. I recommend swapping out your old one with a quarter-turn ball valve like this one.
Heres the reason: quarter-turn ball valves are either on or off.
When your toilet is overflowing you want a functioning shut off valve. So just replace it. I've been working on the bathroom in this rental for several weeks and stuffed a rag into the toilet waste stack. This prevents sewer gas from entering the house. BUT don't forget to remove it...that would be one bad clog!!
When it comes to the wax ring, my personal preference is to place it on the closet flange.
Notice the wax ring is extra large and lacks a plastic horn.
Charlie advised me to avoid the plastic horn because his theory was it would impede the flushing of waste. And he's seen the plastic horn separate from the wax ring and clog the waste stack. The extra large wax ring is simply a little insurance that the seal between it and the bowl will last longer. Line up the closet flange bolts with the holes in the bowl and lower the bowl onto the wax ring. Press the bowl evenly onto the wax ring until it touches the floor. You can even sit on the bowl to do this.
Now it's time to check how level the bowl is. What can you do if the bowl is off-kilter?
Step 4: How to Level the Toilet Bowl
Place your torpedo level on the back of the bowl and check it's levelness left to right and front to back.
I like using plastic Fluidmaster shims to adjust the toilet bowl.
You'll see in the video that I had to shim the front of the VorMax to get it level.
Not a big deal. Just check the toilet bowl with the torpedo level after you shim it. This kinda goes without saying, but don't use wood shims for a toilet bowl project. Wood is food for bacteria and will definitely rot from the moisture in a bathroom. What I like about American Standard toilets is how easy they are to install. You don't need any extra tools for the toilet installation. Grab the nuts for the closet flange bolts and hand tighten them.
After installing the nuts, try to rock the bowl back and forth.
If the bowl does move you can hand tighten the closet flange nuts just a little bit.
Finish off the toilet bowl installation by placing the caps on the nuts.
Now it's time to install the tank...again, this is easier than you think!!
Step 5: How to Install the Toilet Tank (My 12 Year Old Could Do This)
Seriously, my 12 year old daughter could easily install the VorMax tank.
And the nice thing is you only need one tool...which comes with the toilet. The bottom of the tank has 3 bolts and two gaskets.
Align the three bolts with the three holes in toilet bowl.
Gently lower the tank onto the bowl and then use the tool to tighten the nuts.
The tank should rest against the bowl when all three bolts are tightened.
I love this little tool because it makes securing the tank to the bowl a breeze. Plus it's super hard to break the tank with this process. That's kind of important since toilets aren't cheap!! Once the tank is installed you can add the toilet seat. Position the rubber gaskets on the tank, align the seat on the gaskets and place the bolts through the seat/bowl. Add the nuts to the bolts and then it's as simple as tightening the bolts with a screwdriver.
See, I told you this was easy.
Now it's time to add the water supply line. I've got some good tips for you.
Step 6: Adding the Water Supply Line
If there's one place you could have a total disaster it's at the fill valve.
It's super important to get this step right. The other steps are critical, don't get me wrong. But nobody wants to turn on the water and have it spraying all over the bathroom!! The fill valve is what, you guessed it, fills the tank with water. You need a supply line to connect the fill valve to the shut off valve coming out of your floor or wall. I recommend using a steel braided supply line because they're sturdy and rarely leak. Thread the supply line onto the shut off in the clockwise direction by hand, being careful not to cross thread the supply line's fitting.
Then use a crescent wrench to tighten the supply line's nut 1/4 to 1/2 turn.
Yep, that's all you need to do. Super human strength isn't required.
Finally, align the other end of the supply line with the fill valve's threads.
If you're looking up at the fill valve you can tighten the supply line in the clockwise direction.
If you're looking down at the tank and trying to tighten the supply line, do that in the counterclockwise direction. I'm mechanically challenged and am writing this little explanation for anyone who struggles with this stuff.
Most of the time you just need to hand tighten the supply line to the fill valve. But you could turn it 1/4 turn more with a wrench. Time for the ultimate test of your workmanship: turning on the water and flushing.
Step 7: Test Your Workmanship
I totally get that this is the most frightening part.
Turn on the water at the shut off valve and immediately look for any leaks at the shut off/supply line connection and the supply line/fill valve connection. Here's my handy dandy guide to fixing leaks
  1. If you have any leaks at these points, turn off the shut off valve and tighten the supply line fittings 1/4 turn more in the clockwise direction.
  2. If you have any leaks at the tank, tighten the nuts holding the tank to the bowl. BUT be careful not to tighten the nuts too much as this could break the tank.
  3. If you have any leaks at the bowl/floor, it's a wax ring issue. You'll have to remove the bowl from the closet flange and inspect the problem.
Watch how to replace a toilet step-by-step in my video to see all the details and ensure you don't have any issues. I promise you'll feel 100% confident you can do this project after watching the video
Hop into the comments below if you have questions or want to add your own 2 cents.
I welcome extra tips because who doesn't love learning something new. See you down in the comments.
Jeff
Be the First to Share
    • Meatless Challenge
      Meatless Challenge
    • Remote Control Contest
    • Eggs Challenge
      Eggs Challenge
    18 Comments
    igorpkc
    igorpkc
    5 years ago
    Nice tutorial, explains stuff well!
    In Croatia (perhaps the rest of Europe too, idk) we do it a bit differently. There is a special rubber sleeve that connects the outlet of the toilet bowl with the drain pipe in the floor. There's even a sleeve with an offset, as a solution when the drain is positioned too close to the wall, leaving insufficient space for mounting the toilet bowl. Makes life really easier! I also didn't use any wax rings, i just filled the sanitary silicone under the edge of the toilet bowl "foot". This is the rubber sleeve i'm talking about.. Perhaps you have something similar there :)
    JohnG220
    JohnG220
    5 years ago
    Great instructable, thanks for the tutorial. I bought my current house in late 2012 and ever since then I have been contemplating replacing the toilet as it leaves some things to be desired. My question, and apologies if it has already been asked, is: if the existing toilet is *not* an elongated bowl toilet, can it be replaced with an elongated bowl toilet, or can it only be replaced with a non-elongated bowl toilet? Or is it something that depends on certain dimensional details of the space where the existing toilet resides (if so, could you say what dimensional details I should be looking at)? Thanks!
    sharpstick
    sharpstick
    5 years ago
    I never use wax rings any more. When I did, I usually tore up at least one before getting the toilet seated right, and the bolts in place without falling out. There are new rubber rings that are reusable.
    HomeRepairTutor
    HomeRepairTutor
    Reply 5 years ago
    I've seen different versions but haven't tried them. What type are you using?
    sharpstick
    sharpstick
    Reply 5 years ago
    I've used a couple, but don't remember the brand. One difficulty I had on one was that I had to crank the bolts down pretty hard to squeeze it all the way to the floor.
    jdeng44
    jdeng44
    5 years ago
    They sent me replacement and repair cost for the toilet and the damage the water caused. The basement is all dry now and I now have money to redo my drop ceiling with ceiling tracts. Btw do you have any of those Instructables? Would I just use the level used for tiling to measure out the wall for the ceiling tracts?
    HomeRepairTutor
    HomeRepairTutor
    Reply 5 years ago
    That was good of them to send you a replacement. Sounds like they were generous. In terms of the ceiling, we don't have an instructable on that.
    caeric
    caeric
    5 years ago
    Wow thanks for sharing! Have been looking at replacing one of my toilets, and this makes it much less daunting!
    HomeRepairTutor
    HomeRepairTutor
    Reply 5 years ago
    Hope it helps, please feel free to post and questions
    jnoonan2
    jnoonan2
    5 years ago
    My question is, what do you do with the old toilet ?
    HomeRepairTutor
    HomeRepairTutor
    Reply 5 years ago
    In this case, an I know this sounds gross, I'm keeping the old toilet. It's an older American Standard Champion and never leaked. It was just the wrong color for the bathroom remodel. Only problem...where to store it!!!!
    Pa1963
    Pa1963
    Reply 5 years ago
    Some people just smash 'em up and throw the bits in the trash. Some cities will collect them and grind them up and add them to the gravel used in road building.
    Jimaudio
    Jimaudio
    Reply 5 years ago
    I have replaced 2 so far. I put mine in the residential garbage can then I hit it with a hammer many times. It will break up into small pieces and thus save you room in your trash can. You could always put it in front of your house with a Free sign on it. I am not too big on buying used toilets but others might be.
    Pa1963
    Pa1963
    5 years ago
    Some other points. When removing the old toilet, while it's still mounted, flush the toilet, then take a shop vac (if you've got one) attach the hose to the exhaust side of the vac, stick the hose in the toilet, stuff rags around the hose, and blow the remaining water out of the bowl. If you aren't reusing the old toilet, break it up in place. It's way easier to do this than to lug the old toilet out. Also, consider replacing the supply valve with one with 2 outlets, so that you can add one of those bidet hoses. Nothing like facing the world with a squeaky clean pooper! Some installers will apply caulking around the base of the toilet, but this will only mask any leaks, and could lead to a major repair bill. Also, if you have to replace a flange gasket, the caulking could adhere the toilet so firmly to the floor that you might destroy it in trying to remove it.
    HomeRepairTutor
    HomeRepairTutor
    Reply 5 years ago
    Thanks for the extra tips, I like using Oatey's LiquiLock instead of the shopvac technique. It makes the water in the trap a gel. I agree with you on the 'pooper' concept, lol
    jdeng44
    jdeng44
    5 years ago
    Hey Jeff this is a great Instructables but I would just want to add one more hung. I bought a Kohler toilet 2 months ago that kept having a persistent leak despite my own and professional intervention. Long story short the China in the toilet had insufficient glaze. However, this is easily diagnosed by putting the empty bowl on a five gallon bucket and proceed to fill the bowl. With a full bowl, compromised china can easily be seen as a slow drip. On the bright side I was well reimbursed by Kohler for damages.
    Jimaudio
    Jimaudio
    Reply 5 years ago
    Wow that is interesting. I never knew it could leak unless it had a crack in the surface
    HomeRepairTutor
    HomeRepairTutor
    Reply 5 years ago
    Thanks for sharing, that would be a huge disappointment. Great way to diagnose the glaze. Did they send you a new toilet?
