Introduction: How to Rewind BLDC
- Rewinding BLDC motor
Step 1: Introduction
BLDC (Brush Less Direct Current ) Motor most offen used in drones .but unfortunately it will burn during heavy work load .so i will instruct how to recover it inorder to save few bucks
Step 2: Remove the Pin
Step 3: Removing Coil
- remove the out runner
- use screw driver as lever mechanism to remove the coil
Step 4: Winding Coil
- Follow the images
- wind as tight as possible
- clear instruction given on video
Step 5: Decide the Connection
- Go for delta connection u will get more speed
Step 6: Putting Back the Coil
- apply some epoxy to fix the coil tightly
Step 7: Test the Motor
- connect to ESC
- run a test drive
