Introduction: How to Safely Use and Grow Aloe Vera
in this instructable i will be teaching you how to grow and use aloe vera
Step 1: Getting the Aloe Vera
first you need to get aloe vera and that means you need to buy it from a store (i bought mine from ikea) or you need to grow it. when getting it from a store you need to wait about 2 to 3 weeks before it has grown enough to be safe to use.
Step 2: Watering
For growing it you need to water it on average 3 times each month or 4 if you have to. If you water it too many times it will die or become infected without your knowledge and when you try to use it it wont work.
Step 3: Usage
if you do happen to burn cut or have a sore you want to break off a stalk of aloe vera. the safe ammount for you and the plant is about 3 centameters from the top of the stalk. rub it on the area until the piece is empty. after rubbing the affected area you may put the stalk back in the pot or where the plant is to make it healthy due to the nutrients.
Step 4: Thanks
your done reading go awa
