Introduction: How to Save Money on Electricity
Save money on electricity at home with a device called Watt-meter that measure the watt consumed of a device in your house
https://youtu.be/5Wu319QpF-4 With this device http://amzn.to/2wN7lbf you can measure the wattage of any devices till 2500w so try and not exceed that value.In order to save money on your power bill, you have to measure all your devices for standby power consumption http://amzn.to/2xwU23n and try to unplug them when you are not using them.In this video, you will see exactly how many watts of power some electrical appliances consumes when just plugged in and losing your money in the way.
Step 1: The Watt Meter
A modern digital electronic wattmeter/energy meter samples the voltage
and current thousands of times a second. For each sample, the voltage is multiplied by the current at the same instant; the average over at least one cycle is the real power. The real power divided by the apparent volt-amperes (VA) is the power factor. A computer circuit uses the sampled values to calculate RMS voltage, RMS current, VA, power (watts), power factor, and kilowatt-hours. The readings may be displayed on the device, retained to provide a log and calculate averages, or transmitted to other equipment for further use. Wattmeters vary considerably incorrectly calculating energy consumption, especially when real power is much lower than VA (highly reactive loads, e.g. electric motors).
Washing machine 1.6w
Laptop charger 0.7w Toothbrush charger 0.7w Lcd tv 5w And much more but the time is too precious you will find them all if you gonna purchase one of this watt-meter.
If you find this video useful like share and subscribe https://www.youtube.com/channel/UCPjqH3HfNA4Shttkx1haAUQ
Step 2: Lets Start Measure Some Appliances
First on our list is the washing machine
(laundry machine, clothes washer, or washer) is a machine used to wash laundries, such as clothing and sheets? The term is mostly applied to machines that use water as opposed to dry cleaning (which uses alternative cleaning fluids, and is performed by specialist businesses) or ultrasonic cleaners. Laundry detergent is added to the wash water and is sold in either powdered or liquid form.
We can observe that even when is not working just staying plugged into the wall it draws power
1.6w every hour, day after day and in one-year approx 15kw are lost by just ignorance and let it there just sitting plugged-in when removing or turning off the socket can save you some real money year after year.
Step 3: The Laptop Charger
A laptop, often called a notebook or "notebook computer", is a small, portable personal computer with a "clamshell" form factor, an alphanumeric keyboard on the lower part of the "clamshell" and a thin LCD or LED computer screen
on the upper part, which is opened up to use the computer. Laptops are folded shut for transportation, and thus are suitable for mobile use. Although originally there was a distinction between laptops and notebooks, the former being bigger and heavier than the latter, as of 2014, there is often no longer any difference. Laptops are commonly used in a variety of settings, such as at work, in education, in playing games, Internet surfing, for personal multimedia and general home computer use.
This useful device came with the charger that plugs into the mains for recharging the laptop batteries and this device left plugged in the wall days after days can cause a loss of 0.7w each hour that is plugged into the socket and not charging so approx 6kw are lost in this charger let's move to another one....
Step 4: Electric Toothbrush
An electric toothbrush is a toothbrush that makes rapid, automatic bristle motions, either back-and-forth oscillation or rotation-oscillation (where the brush head alternates clockwise and counterclockwise rotation), in order to clean teeth. Motions at sonic speeds or below are made by a motor. In the case of ultrasonic toothbrushes, ultrasonic motions are produced by a piezoelectric crystal. A modern electric toothbrush is usually powered by a rechargeable battery charged through inductive charging when the brush sits in the charging base between uses.
Electric toothbrushes can be classified according to the frequency (speed) of their movements as power, sonic or ultrasonic toothbrushes, depending on whether they make movements that are below, in or above the audible range (20–20,000 Hz or 2400–2,400,000 movements per minute), respectively.
And this device comes with a charger that left to many hours plugged in can result in energy loss of 5kw
Step 5: So Friends Go and Measure Your Appliances
https://www.youtube.com/channel/UCPjqH3HfNA4Shttkx1haAUQ Thanks for watching and see you next time all the best! Others electronic projects with NO Skills Required: Washing machine motor generator https://www.youtube.com/watch?v=_jKTsAJK8aQ Washing machine motor wiring basics https://www.youtube.com/watch?v=XlaHSZFGzp0 Washing machine motor speed control https://www.youtube.com/watch?v=lRj6V7ygBQo Incredible washing machine motor on battery https://www.youtube.com/watch?v=TcMUTqSvOsw
