Introduction: How to Send SMS From A9G Board by Sending AT Commands From Raspberry Pi Pico W Using MicroPython Programming
In today's interconnected world, communication is key. Whether it's for IoT applications, remote monitoring, or simple notifications, the ability to send SMS messages from a microcontroller can be incredibly useful. In this guide, we'll explore how to leverage the power of the Raspberry Pi Pico W and the A9G board to send SMS messages effortlessly.
Step 1: Setting Up Raspberry Pi Pico W & A9G Board:
- Connect the Raspberry Pi Pico W to your computer using a USB cable.
- Power up your A9G Board by Connecting the A9G board to your computer via USB cable.
- Connect Raspberry Pi Pico with A9G as per below connection Diagram.
- Launch Thonny IDE and create a new Python script.
- Write and upload the requisite code to establish serial communication with the A9G board.
Step 2: Code to Send SMS:
Here's a Python script to send an SMS using the Raspberry Pi Pico W and the A9G board:
# Import required libraries
import machine
import time
# Configure UART for communication with the A9G module
uart = machine.UART(0, baudrate=115200, tx=machine.Pin(0), rx=machine.Pin(1)) # UART0 on Pico
# Function to send AT commands and receive responses
def send_at_command(command):
uart.write(command + '\r\n') # Send the command
time.sleep(3) # Wait for response
response = uart.read() # Read the response
if response:
print("Response:", response.strip()) # Print the response
return response.strip()
else:
print("No response received.") # Print if no response received
return None
# Function to send an SMS
def send_sms(phone_number, message):
# Set text mode
response = send_at_command('AT+CMGF=1')
if not response or b'OK' not in response:
print("Failed to set text mode.")
return
# Set recipient number
response = send_at_command('AT+CMGS="{}"'.format(phone_number))
if not response or b'>' not in response:
print("Failed to set recipient number.")
return
# Send message
response = send_at_command(message)
if not response:
print("Failed to send message.")
return
# Send Ctrl+Z to end message
uart.write(chr(26))
time.sleep(1)
# Example usage
phone_number = '+91XXXXXXXXXX' # Replace with recipient's phone number
message = 'Hello, this is a test message from Raspberry Pi Pico W with A9G board!'
Step 3: Conclusion:
With the provided code and setup instructions, you can now easily send SMS messages using the Raspberry Pi Pico W and the A9G board. Whether you're building IoT applications or remote monitoring systems, the ability to send SMS messages adds a powerful communication layer to your projects. Experiment with different messages and recipients to explore the full potential of this functionality!
