Introduction: How to Setup Electronics of RC Aircraft Without Flight Controller
Creating your own RC aircraft can be a very rewarding experience, but the real excitement begins when you start working on the electronics. Although wiring up your flying machine may seem like a challenging task, don't worry, as this guide will help you through all the essential steps required to set up your RC aircraft's electronics. By following these instructions, you'll be able to transform a pile of parts into a flying masterpiece.
Step 1: Making for Airframe
Firstly make an aerodynamic airframe by considering various factors like lift, payload capacity, airfoil, etc.
Material Can Be Used:
1) Balsa Wood
2) XPS Sheet
3) Plastic Corrugated Sheet
4) Glass Fiber
5) Plastic Fiber
Step 2: Setting of Electronics
We will use 3 Servos for the movement of the control surface
SERVO 1 - Aileron - Roll moment
SERVO 2 - Elevator - Pitch Moment
SERVO 3 - Rudder - Yaw Moment
We will use the ESC to control the RPM and Speed of the motor
Step 3: Setting the Channels in Receiver and Transmitter
Set Servo 1 (Aileron) in channel 1
Set servo 2 (Elevator) in channel 2
Set servo 3 (Rudder) in channel 4
Set ESC in channel 3
Step 4: You Can Refer These Diagram for the Connection
