Introduction: How to Sew a DIY Blanket Jacket (No Pattern Needed!)
Thrift stores are gold mines for budget-friendly and sustainable materials like fabric, curtains, blankets, clothes of course, and other materials you can transform into fashion like what I’m using today. Here's how to sew a thrifted blanket into a one of my new favorite jackets without using a pattern!
- blanket (I thrifted mine from Savers)
- fabric scissors
- a jacket you already own that fits you well
- zipper (I used a 23-inch zipper)
- sewing clips
- sewing machine
I may receive a commission for purchases made through product affiliate links in this post.
Step 1: Fold and Cut
Fold the blanket in half and cut along the bottom. If your blanket has words, you may have to move the pieces around the figure out the placement that you want for the final jacket.
Step 2: Cut Out the Body Portion
Place your guide jacket on top of the folded blanket. Fold the sleeves in and out of the way and cut around, about an inch bigger for seam allowance. Cut down the center of the front layer of fabric and that’s where the zipper will go.
Step 3: Cut the Sleeves
Fold the remaining pieces of fabric in half so there are two layers to each, and then use the sleeve from the guide jacket to cut the right shape and size (again, about an inch bigger for seam allowance). Make sure the seams are at the bottom of each sleeve, so the folded edge of the fabric should be at the top.
Step 4: Cut the Collar
Cut a piece of fabric along an already finished edge that’s about 3-4 inches tall and the same length as the neck from one side at the front where the zipper will be around to the other side. The length from the bottom of the jacket to the top of the collar should be the same as the length of your zipper.
Step 5: Clip the Pieces Together
Clip pieces right sides together.
Step 6: Sew and Attach Pieces
Sew along all clipped seams. To attach the sleeves, slip it into place from the inside of the body piece, right sides together. The sleeve should be right side out and the body part should be inside out. Clip it in place and sew them together.
Step 7: Add Hem Lining
Finish off the hemline on the bottom of the body and sleeves. I'm using brown lining from the original blanket, but you can also just fold and hem the bottom, use binding tape or even an elastic finish. Clip and sew.
Step 8: Add the Zipper
Now it’s time for the final step—adding the zipper! Clip each side of the zipper to each side the opening, right sides together and sew to attach.
Step 9: All Done!
That's it! You now have a cute and cozy jacket that you can proudly say was sustainably made. Subscribe to my YouTube channel for more tutorials and let me know if you try this one out!
