Introduction: How to Single Crochet
This is a basic guide to a single crochet. This teaches you the basic of single crochet. You can create squares and crochet a patchwork cardigan or whatever project you have in mind.
You will need yarn. The color is up to you. You will also need a needle and the needle size depends on your yarn size.
Step 1: Create a Slip Knot
You will begin by creating a slip knot.
Step 2: Create a Foundation Chain
You can create how many chains needed for you project depending on the length of your measure object. For my project, I made twenty chains.
Step 3: Single Crochet Into the Foundation Chains
Insert your needle into the second chain. you will then yarn over, pull through a loop, and then yarn over again and pull through both loops.
Step 4: Single Crochet Into the Foundation Chains
You will repeat the previous steps until you get to the end of foundation chain.
Step 5: Turning the Crochet Pattern
Chain one and turn your project so you will be looking at the backside of the project.
Step 6: Single Crochet Another Row
You would make a single crochet in the first stitch. You will repeat step three in this process.
Step 7: The Finished Product
You will repeat steps three through six to create your desired project.
