Introduction: How to Solve a Pyraminx
The Pyraminx is one of the easiest cubes that exist. In this instructable I will show you how to solve a Pyraminx in 3 steps.
Things needed:
- a Pyraminx (https://www.amazon.com/CuberSpeed-Qiming-Pyramid-Black-MoFangGe/dp/B07811MJCP/ref=sr_1_8?keywords=pyraminx&qid=1669579284&sr=8-8)
- Your working mind
Step 1: Solve a Surface
In this instructable I'am going to work with the green surface. You also can do this with every other surface .
First of all you must solve the green surface. You must do this without algorithms.
Step 2: Longest Step
In the first picture you see how with direction you have to turn. The i stand for inversed.
If you have the green surface, you must turn the Pyraminx like in picture 2 and do the algorithm L RI LI R. After that you have to turn the Pyraminx from picture 3 to picture 4. Then you must do the algorithm LI R L R. This algorithm you have to repeat until you become the result like in picture 5.
Step 3: Last Step
Now you have to put one corner on the right place and do the algorithm R U Ri U. Repeat this until you have all the corners are right (picture 1). It could be that you must turn the hole top to place the corner right.
Step 4: Done!
So, now you know how to solve a Pyraminx. Let me know in the comments if you got it !
