Introduction: How to Solve a Rubix Cube
Hi Guys Before i start i would like to give an awful lot of credit to poisontiger who taught me in the first place how to do this and whos videos im using. thanks poisontiger!!! anyway this is how to solve a rubix cube
Step 1: You Will Need..
A rubix Cube!! (3x3)
This instructable!
Time
Patience
Pratice
Well if you have all these thing lets get on!
This instructable!
Time
Patience
Pratice
Step 2: Upper Cross
This will teach you how to do the upper cross
once youve done this a few times and got it memorized go on to the next step!!
Step 3: Solving the First Layer
Same as previous step Learn, Pratice, Memorize and go on to the next step!
Algorithm used in this step: (Ri Di R D (1, 3 or 5 times))
Step 4: Middle Layer
I don't need to say it again but... Learn, Pratice, Memorize and go on to the next step!
Algorithms used it this step
Move Right (U R Ui Ri Ui Fi U F)
Move Left (Ui Li U L U F Ui Fi)
Step 5: Upper Cross
I'm not going to say it
Algorithm used in this Step (F R U Ri Ui Fi)
Step 6: Top Edges
You got it so far?
Algorithm used in this step (R U Ri U R U U Ri)
Step 7: Getting the Top Corners in Place
You should have a nearly solved rubix cube by now!!=) (I HOPE!)
Algorithm Used for this step (U R Ui Li U Ri Ui L)
Step 8: Solving the Cube!!!!
This is the best step!! the cube looks all mixed up and..... its solved!!!
Algorithm used in this step (Ri Di R D(x2 or 4))
Step 9: Well Done!!
If you have a solved cube... WELL DONE!!!!! =) if not=( try again soz!
i hope this helps lots of people solve there cubes!!!!!
