Introduction: How to Speed Up a Slow Windows Computer
This article will teach you a few tricks to help improve the speed and performance of a Windows computer. For this walk through I will be using Windows 8 operating system however, the steps can be easily applied to Windows 7 OS as well. Each step should only take a few minutes. The following methods should be used as often as once every week in order to maximize your computer's performance and capability.
What You Will Need: Access to a computer running Windows 7 or Windows 8 OS
Time: Each step shouldn't take more than a few minutes
Difficulty: Beginner
Step 1: Delete Any Unnecessary Programs
Keeping old programs on your computer is a good way to take up space and memory. Soon after deleting a few big programs that you do not need, you will notice the increase in speed.
1. Click the windows button (the start menu found in the bottom left hand corner)
2. Search "uninstall" in the search bar, select "uninstall a program" in the menu of options found
3. The programs will be automatically listed in order of largest size to smallest. Take a look through these programs and try and find a few that you either haven't used in awhile or do not plan on using in the future
4. Select the program you have chosen with a single mouse click, then select the "uninstall" button that will appear
5. The program will guide you through an installation wizard, just follow it through until the program has been completely removed
6. Go through and repeat steps 4-5 for any program in the list you feel that you do not need
WARNING: ONLY delete programs that you have installed whether it be on purpose or by accident. Deleting a program that you just do not recognize may cause serious problems elsewhere on your computer.
Step 2: Change Your Start Up Programs
Start up programs are applications that begin to run as soon as you turn on your computer. This can cause problems due to the fact that many of these are not needed and leaving them running in the background will take up memory and space that your machine could be putting to better use.
2. Type "msconfig" in the search bar, select the first option
3. Select the "startup" option from the top tabs
4. Click the "Open Task Manager" link
5. Task Manager will now display a list of programs that are set to run upon start up. Read through this list and decide which ones(if any) you would be able to run your computer without
6. Remove any chosen programs by clicking on the program's name, then clicking the "disable" button that will appear
Step 3: Run Disk Defragmenter
Disk Defragmenter is a Windows tool that automatically unclutters and reorganizes the data stored in your hard drive. Defragmenting allows the computer to be able to find and access any requested data faster, therefore improving overall speed.
2. Type "defrag" into the search bar
3. Select "Defragment and Optimize Drives" option from menu
4. Make sure the C: drive is highlighted, then click the optimize button in the bottom right corner
5. Windows will now defragment your C: drive and show completed when it is done
Step 4: Clean Up the Hard Disk
Disk Cleanup is a tool that quickly and easily deletes files on your computer that you may no longer need. This tool empties folders that most users do not even know exist. These folders can be filled with files, downloads, or cookies that you may have never even seen before. Deleting these files this provides more disk space which can improve speed as well.
2. Search "cleanup" in the search bar, then select "Disk Cleanup"
3. Select OK to continue using the C: drive
4. Make sure that "Download Program Files", "Temporary Internet Files", "Offline Webpages", and "Recycle Bin" options are all checked then click OK to clean disk
5. Disk Cleanup will run and the program box will disappear once complete
Step 5: Adjust Computer to Best Performance
One of the big things that can slow a Windows computer down is all of the visual effects. These effects do make a much more appealing graphical environment for the user, but sacrificing them is a great way to improve speed and performance. The only place these effects will show is your start menu, icons, desktop, windows, etc. It will not affect any visual effects or graphics for websites, programs, or games.
1. Select the windows button
2. Search "appearance" in the search bar then select "Adjust Appearance and Performance of Windows"
3. Select the option "Adjust for best performance" then click apply
4. The changes will take a moment to take effect. After they have been applied click OK to exit
Step 6: Monitor Devices Using WiFi
The more devices that are connected to a WiFi network, the slower your connection speed will be.
1. Check to find any internet devices that could be currently connected to your WiFi
2. If you find a device connected that you aren't immediately using, disconnect the WiFi. This can include laptops, tablets, phones, and devices such as Roku or Chromecast. The easiest way to make sure devices like Roku or Chromecast aren't using up any speed is to turn them off completely
3. Disabling any extra devices helps improve connection speed in almost any situation.
TIP: The fastest connection will always be gained by connecting your computer directly to the internet with an Ethernet cable. If this isn't an option then try to make sure the router is located as near as possibly to your computer. The closer a computer is to the internet router, the better.
