How to Split Firewood...With a Knife
Intro: How to Split Firewood...With a Knife
Hi Folks! Welcome to my first Instructable!
First of all, this method was not originally my idea. I noticed that there was not an Instructable on this subject, and I decided to make one. Feel free to leave tips, suggestions, or questions in the comment section.
This technique is known as Batoning, and it is most useful (in my experience) when splitting thin pieces of wood for kindling, or for when the surface you are splitting on is not completely level.
From Wikipedia: This technique is useful for the simple splitting of wood for kindling, to access dry wood within a wet log, and for the production of shingles, slats, or boards. It is also useful for cutting notches, or making clean crosscuts against the grain of the wood. Batoning requires much less energy to perform than chopping, which is helpful in survival situations where energy should be conserved. The technique is also especially useful when a chopping tool is not available.
STEP 1: Gather Materials
Safety First:
Eye Protection
Work Gloves (I'm not using gloves because it was hard to work the camera with gloves on)
Sturdy Shoes
Splitting wood can be a dangerous activity. I am not responsible for any injury to yourself or others as a result of this method. Be Careful.
A stump/sturdy surface
A log to use as a club/hammer
Should be easy to hold and swing with one hand
A fixed-blade knife
The knife you use should have a thick spine, and a grippy/secure handle.
Do not use a kitchen knife; do not use a folding knife. Both will probably break.
The blade of the knife needs to be longer than the diameter of what you intend to split
Warning: There is the potential that the blade of your knife will break off into the log. I have never had this happen to me, but just beware.
Wood to split: Should be cut to size to use in a fire.
Eye Protection
Sturdy Shoes
A fixed-blade knife
STEP 2: Positioning the Log
Select a piece of wood you wish to split.
If you can, stand the piece of wood vertically upright on the stump/platform you are using. If not, hold the piece of wood upright in you right hand and press down on the wood with your knife in your left hand, so that it doesn't fall over. You can then remove your right hand and retrieve your club.
Note: You want to be holding the knife in your non-dominant hand. If you’re left handed, hold the knife in your right hand and the club in your left hand.
STEP 3: Splitting the Log
Tap the spine of the knife with the to get it firmly lodged in the log. Once it
is lodged hit the spine of the knife again with a series of hard swings until
the spine in below the top of the log. Now,
hit the tip of the knife repeatedly until the log splits. You can continue doing this with each log half that you split to get pieces small enough to use as kindling.
STEP 4: Tips and Troubleshooting
Firmly press down on the handle of the knife as you are splitting. This will help keep the tip of the blade traveling farther than the
handle. If this does happen, hold the log at the top in your hand press down on the handle to attempt to even it out. If that doesn't work, hold the log at the top in your hand and hit the handle of the knife with enough force to make the blade and handle even.
STEP 5: Thats All!
Have fun and be safe!
25 Comments
RobertW172 7 years ago
Some more stuff here to assist in filling the gaping holes in my knowledge!
Many thanks
jvaupel 10 years ago
very kewl!
pav1956 10 years ago
I use my Becker Campanion
See: http://www.kabar.com/knives/detail/182
It is made by Ka-Bar was designed for work!
Also split the log (quartering it) and wrap the bottom with twine or hold the bottom togeather with rocks and you can have a Swedish Stove!
See
https://www.instructables.com/id/How-to-make-a-Swed...
Ricardo Furioso 10 years ago
Works perfectly. Great Instructable. Thank you.
cfm 10 years ago
stevetork 10 years ago
smokehill 10 years ago
If weight is not a consideration (which it would be to some backpackers), there is also a tool, sometimes called a Wood Grenade, that is made of hardened steel & shaped like an ice cream cone with a flattened top. You stick the pointy end in the center of a short log, hit it with a HEAVY hammer, and the wood splits, usually in several pieces at once. I make my kindling with it, using a small sledge (several pounds weight). Works better with dry, seasoned wood, obviously.
For those who didn't grow up with a wood stove, you should know that there is an UP and a DOWN side to splitting wood. The grain is further apart closer to the roots, so you should turn the wood UPSIDE DOWN from the way it grew, to make it somewhat easier to split. Also, starting your cut in a radial crack (if there are any) saves some elbow grease.
And SHARPEN your ax or hatchet, if you use one, regularly. Saves lots of time & work, and lessens the chance you'll have a tragic accident.
gpay10 10 years ago
mikecz 10 years ago
I sent the tool to Leatherman with exactly this story AND THEY REPLACED IT! So, I'm not gonna do that to the Leatherman again but I have to say this was warrantee above and beyond my expectations!
Basement_Craftsman 10 years ago
gijoebob 10 years ago
gare8421 10 years ago
keng 10 years ago
The Metal One 10 years ago
LexieGuitar 10 years ago
zucchero 10 years ago
bgipson1 10 years ago
and should considered an
emergency means of
splitting wood when you have to a fire to survive otherwise use a small hand axe or hatchet
tim_n 10 years ago
If you've got a saw to cut the logs, you've probably got an axe for splitting them.
Don't forget axes aren't all for splitting
mountainfish 10 years ago
rhackenb 10 years ago
