How to Strip Furniture With Citristrip
Intro: How to Strip Furniture With Citristrip
I love to thrift for accent furniture pieces for my home. But, so often the wood tone is orange, red, or cherry, depending on the era of the piece. Stripping furniture is one way to get rid of that unwanted wood tone. Stripping furniture is not for the faint of heart! It can be laborious and tedious! This guide on How to Strip Furniture with Citristrip will help with that!
Disclosure: I am not a professional furniture restorer, I am only a hobbyist, and these are the steps that work for me. DO NOT attempt to strip a priceless family heirloom or antique on your own-you should probably leave that to professionals. This is not sponsored by Citristrip.
STEP 1: Step 1-Sand
Give your object a good sanding. Electric sanders are great for large
surfaces, but you will probably need a block sander or sandpaper to get into the smaller grooves or curves.
STEP 2: Step 2-Wipe Down
After sanding, wipe your piece down with a damp rag or blue shop towel.
The blue shop towels work much better than paper towels because they don’t easily disintegrate or leave debris. They can also be rinsed out and used again. Some people prefer to use a tackcloth, but I find they leave a sticky residue.
STEP 3: Step 3-Apply Citristrip
The remaining steps must be done outside! Put on chemical resistant gloves and eye protection. Shake the Citristrip bottle well. Pour some Citristrip into your soup can, or other metal container. In the picture above, you’ll see that I poured it into a red disposable cup. This will work for a few hours, but then the Citristrip eats away the bottom of the cup. Brush on a thick, heavy coat with a chipbrush. Be sure to get into every nook, cranny, surface, and crevice. Double and triple check that every surface has a thick coat applied.
STEP 4: Step 4-Wrap in Plastic Wrap
After the Citristrip is thickly applied to every surface, wrap it all up in plastic wrap. (You WILL NOT be able to reuse this plastic wrap package for food! Just keep it with your materials for the next project.) You will want a better quality plastic wrap than what I used! You want it to really seal well. I leave it wrapped up overnight, but it’s best that you can get back to it within 24 hours!
STEP 5: Step 5-Strip
With gloved hands, remove the plastic wrap. Begin scraping the surfaces with the plastic scraper. Ideally, the stain will just scrape off. If not, it’s time to really put in the elbow grease! You have two options at this point, wipe the piece down with a wet rag, rinsing the rag often, and repeat Steps 2-5, or start scrubbing down the piece with steel wool or Scotch Brite. You can pour mineral spirits on the steel wool or Scotch Brite and scrub some more.
STEP 6:
Because every stained piece was made with a different product and process, this step is more of a trial and error to see what works the best. Remember, stripping is not for the faint of heart! Strip and scrub and rinse, strip and scrub, and rinse, and even sand again until you get your desired result. Scrub the piece down with mineral spirits and a rag or blue shop towel to be sure that all of the Citristrip has been removed. If you are planning on staining your piece, condition with wood conditioner, following the manufacturer’s directions.
5 Comments
seamster 3 years ago
Faith and Farmhouse 3 years ago
