Introduction: How to Take Off Truck Tire
this is a step by step on how to take off a truck tire
for this you will need socket wench, socket, 2inch pipe, a truck a shop
Step 1: Socket Wench
this is what its gunna look like when you have the socket wench with the 22(mm) socket
Step 2: When You Put the Socket on the Lug Nut
at this step you will line up the 22(mm) socket with the lug nut on the rim and then you slide the socket on with the wench
Step 3: Taking the Tire Off
this is what the socket on the tire looks like and with the pipe on
Step 4: Getting the Tire Off
So once you get the wench on the lug nut you have to turn it to the left and do that 8 times of six depending on what kind of truck/car you have
Step 5: Taking the Tire Off
you are going to need a sledge hammer to hit the tire off of the hub and then you are going to swing the hammer sideways and hit the tire on the side and make in come off
Step 6: Final
ok so now you have the tire off of the truck now you can look at your brake caliper and then you put the tire on of the ground and then leave it there till you need to put it back on
