Introduction: How to Thread Bobbin on Kenmore Sewing Machine Model 12
In this tutorial, I will show you how to pull bottom thread up
Step 1: Sewing Machine
I am using a Kenmore sewing machine for this tutorial
Step 2: Expose Bobbin
Remove the 2 trays to access bottom bobbin
Step 3: Prepare Bottom Bobbin
-Life the latch to unlock the bobbin from case
-Pull thread away from you
-Insert bobbin into bobbin case
-Pull thread under tension spring
Step 4: Put Bobbin Back
-Pull lever out
-Insert bobbin into bobbin case and release lever
-Pull thread to give a few inches from the bobbin
Step 5: Bring Bottom Thread Up
-Grab the wheel from right of sewing machine and turn toward you
-Keep turning until bottom thread in this position
-Pull top thread and it should form a loop and catch bottom thread up
-I use a small fork to pull bottom thread up
