Introduction: How to Thread a Needle
Basic sewing is an important skill to learn. Most people should learn how to sew on a button or repair small tears. Knowing how to thread a needle is the first step to any hand sewing project, regardless of scale. This is a vital skill that everyone should know how to do safely.
When threading a needle, take care to avoid injury via its sharp point or from the sewing scissors. Threading a needle for the first time should not take longer than 5 minutes, and is a task that becomes faster with practice.
  1. A sewing needle
  2. Your thread of choice
  3. Sewing scissors (if you do not have sewing scissors, a sharper pair of regular ones will work)
Step 1:
Cut a piece of thread thread to your desired length.
Step 2:
Wet one end of the thread to prevent fraying. You can do this with water, as I have here, or if you are feeling brave, with spit.
Step 3:
Take your sewing needle and line the hole, or "eye," at the top of it with the wet end of the thread.
Step 4:
Carefully guide the wet end of the thread through the eye.
Step 5:
Once through the eye, pull the thread until the needle is positioned on it near the middle of the length of thread.
Step 6:
Take the ends of the thread and tie them into a knot.
Step 7:
You are now able to use the threaded needle to safely start your sewing project.
