Introduction: How to Tie a Half Windsor Knot
Note: The pictures that follow are mirrored to make it easier for you to see what you're supposed to be doing. You don't have to imitate the images exactly. Please feel free to use whichever hands feel most comfortable.
Step 1: Getting Started
Step 2: Now We're Uneven
Step 3: Cross Over
Step 4: Get Behind Me
Step 5: Upper Hand
Step 6: Through the Looping Glass
Step 7: Double Cross
Cross the wide end of the tie over to your left side.
Step 8: Under and Over
Step 9: Loosen Up
Raise the wide end of the tie up to give you a clear view of the knot. Then loosen the front layer of the knot, forming a gap.
Step 10: Tie It Down
Take the wide end and push it down through the hole you have just made, then grab the wide end from underneath and pull it through gently.
Step 11: Adjustin' Tie
Adjust the tie by holding the knot with one hand and gently pulling the narrow end with the other.
Step 12: Additional Notes
For a cleaner-looking knot, grab the tie around your collar on either side of the knot and pull gently to widen it.
To undo the knot, simply hold the knot with your and pull the narrow end out of it upwards.
If the narrow end extends past the wide end, undo the knot and start again at step 1, allowing the wide end to hang even lower. Try to tie the knot as high as you can while still being able to see it.
