Introduction: How to Trim MP4 Files for Free?
Do you need to cut out the middle of your MP4 video for making a new video or uploading onto other video sharing site? Just got a long video but intend to trim the beginning part of it, but haven’t found an easy way? When you tried to use Windows Movie Maker to trim MP4 file, unfortunately, you failed. Actually, there is a free online service called Video Grabber that you can use to trim video easily. Below is the step-by-step instruction you can refer to.
Step 1: Visit Video Grabber Webpage
Open your web browser on PC and go to Video Grabber webpage.
Step 2: Launch Video Grabber
Tap the second “Convert Video” tab and “Select files to Convert” button on its main interface. If you are the first-time user, you need to install and run the launcher. Only by installing it once, you can use it without any limitation. After running it, it will direct you to choose the file.
Step 3: Start to Trim Your File
Click “Edit” button. Then input the start and end time of your trimming file in “Trim” pane. Click “OK” if you are done.
Step 4: Output the Trimmed Video
Click “Format” to choose the output format. It supports many kinds of video formats including MP4, AVI, 3GP, WMV, MKV, VOB, DV, etc. You can set the video and audio parameters by clicking “Settings” button. Click “Convert” button. After converting, click “Open” button to find it on your PC.
Step 5: Conclusion
Video Grabber can also be used to download videos, record screen and convert video files.
