Introduction: How to Turn Wifi On/Off Using Command Prompt!!
About: I post how to videos on youtube and run my own business on the side making hand crafted keychains, Jewelry and other items. One of my main goals in life is to help as many people as I can and just knowing that…
This Instructable will show you how to turn the wifi on your computer on or off using command prompt
Please subscribe to my channel
Step 1: Open Command Prompt
1. Open the Start Menu
2. Type Command Prompt in the Search Bar
3. Right Click on Command Prompt
  • It should be listed under Programs
4. Select Run as administrator
  • If you get a pop up click Yes
Step 2: Type Command to Get the Index Number for the Wifi Adapter
1. Type wmic nicget name, index
  • nic stands for network interface card
2. Find the index number for your wifi adapter
Step 3: Type Command to Turn Wifi Off
1. Type wmic path win32_networkadapter where index=(index number for wifi adapter) call disable
  • For the example shown in this article the index number for the wifi adapter is 7, so you would type wmic path win32_networkadapter where index=7 call disable
2. Press Enter
  • Once you press enter your wifi should turn off, the icon should disappear, and it should say not connected - no connections are available
Step 4: Type Command to Turn Wifi On
1. Type wmic path win32_networkadapter where index=(index number for wifi adapter) call enable
  • For the example shown in this article the index number for the wifi adapter is 7, so you would type wmic path win32_networkadapter where index=7 call enable
2. Press Enter
  • Once you press enter your wifi should turn on, the icon should reappear and it should say not connected -connections are available
3. Close Command Prompt
