Introduction: How to Unblock a Sink With Your Bare Hands When You Have No Plunger
In this Instructable you will find out how to unblock a sink with your hands when you have no plunger.
I worked out how to do this some time ago when my sink was blocked. I wracked my brain for something I might have which I could use instead and realised my hand was a good substitute.
The video demonstrates the technique clearly, with the stages described in the steps.
Not recommended for toilets.
When I'm not writing Instructables I love inventing things. Recently I invented some great ear plugs which are ideal if you get sore ears when you have a bath or shower. If this is a problem for you it might be that you are getting a form of swimmer's ear from water and soap going in your ears. Wearing a pair of my ear plugs from https://zenplugs.com/swimming-earplugs/ will keep the water out and stop your ears getting sore and itchy. They are also great for sleeping and blocking noise as they are multipurpose.
Step 1: Fill the Sink With Warm Water
Fill the sink with hot water, if it's not already full. Make sure the plug isn't in. Hot water will help shift a fatberg in your U-bend but make sure it's not so hot it will burn you.
Step 2: Cover the Overflow
Put one hand over the over-flow to stop the air coming out. Make sure you've got a good seal so the air is forced down the drain and not out of the overflow.
Step 3: Use Your Hand As a Plunger!
Cup your other hand over the plug hole under the water and forcefully move it up and down, forcing water in and out of the plug hole for about 10-15 seconds. Try repeating if it doesn't work the first time.
Step 4: The Sink Is Unblocked!
Hey presto! Your sink is unblocked!
