Introduction: How to Usb-ify Anything
Picture of usbified led
1 3V LED
3V Coin cell battery
1 Wire (Any Size)
1 Alligator Clip
1 Female USB Cable
DVD for stabilizing (optional)
Step 1: Cutting the USB Wire
Start by cutting the Female USB Wire at the end.
Wether it's USB-A USB-C MicroUSB USB-B Just cut the end of it.
Step 2: Attach the Alligator Clip to the Wire
Start by getting your alligator clips
Then get your wire, And finally Attaching it to the near end of the alligator clip.
Step 3: Insert the Alligator Clip Into the USB Wire
Start by getting your alligator-wire clip that you made in the last step
Then insert the end of the alligator clip into the Female USB Wire.
Step 4: Set Up the Battery
Get your DVD and loop the wire through it as shown in the picture above
Put the negative side of the battery on top of the wire which is indicated by a rough surface
Make sure it is seated properly.
Step 5: Connecting the LED
Put the postive wire on the top side of the battery
If you don't know the polarity of your LED
See the picture provided with the polarities above.
Step 6: Test Your Circuit
Connect the USB Wire to the negative side
And test if your circuit works
In the image provided above my circuit works!
