Introduction: How to Use Detect Color TCS3200 With SkiiiD
A tutorial to develop Detect Color TCS3200 with skiiiD.
Step 1: Launch SkiiiD
Launch skiiiD and select New button
Step 2: Select Arduino UNO
Select ① Arduino Uno and then click ② OK button
*This is Tutorial, and we use Arduino UNO. Other boards(Mega, Nano) have the same process.
Step 3: Add Component
Click '+' (Add Component Button) to search and select the component.
Step 4: Saerch or Find a Component
① Type 'Color' on the search bar or find the Detect Color TCS3200 on the list.
Step 5: Select Detect Color TCS3200
② Select Detect Color TCS3200 Module
Step 6: Pin Indication and Configuration
#4 then you can see ③ pin indication. (You can configure it.)
*This module has 8 pins to connect
skiiiD Editor automatically indicate pin setting *configuration available
[Default Pin Indication for Detect Color TCS3200] in case of Arduino UNO
GND: GND
OE: GND
S1: 2
S0: 3
VCC: 5V
OUT: 4
S2: 5
S3: 6
After configuring pins ④ click ADD button on the right below side
Step 7: Check Added Module
⑤ Added Module has appeared on the right panel
Step 8: SkiiiD Code of Detect Color TCS3200
skiiiD Code is intuitive function-based codes. This is based on skiiiD libraries
getFrequency(
"Return the frequency of detected color corresponding to the variable 'color'.
In order to return the variable 'color', choose 1 from "red", "green", "blue" as the color of frequency.
Set the scale of the frequency as the variable 'scale' value. The default scale is 100."
getColor()
"According to frequency detected, return a color from "red", "green", "blue".
Step 9: Contact and Feedback
We are working on components and boards libraries. Feel free to use it and feedback us, please. Below is contact methods
email: contact@skiiid.io
twitter: https://twitter.com/skiiiD_official
Youtube: https://www.youtube.com/channel/UCfS2RQL3m3hVoHkF...
skiiiD user forum: https://www.facebook.com/groups/skiiiD/
Comments are fine too!
