Introduction: How to Use Gas MQ-6 With SkiiiD
A tutorial to develop Gas MQ-6 with skiiiD.
Step 1: Launch SkiiiD
Launch skiiiD and select New button
Step 2: Select Arduino UNO
Select ① Arduino Uno and then click ② OK button
*This is Tutorial, and we use Arduino UNO. Other boards(Mega, Nano) have the same process.
Step 3: Add Component
Click '+' (Add Component Button) to search and select the component.
Step 4: Saerch or Find a Component
① Type 'Gas' on the search bar or find the Gas MQ-6 on the list.
Step 5: Select Gas MQ-6
② Select Gas MQ-6 Module
Step 6: Pin Indication and Configuration
#4 then you can see ③ pin indication. (You can configure it.)
*This module has 4 pins to connect
skiiiD Editor automatically indicate pin setting *configuration available
[Default Pin Indication for Gas MQ-6] in case of Arduino UNO
A0: A0
DO: 2
GND: GND
VCC: 5V
After configuring pins ④ click ADD button on the right below side
Step 7: Check Added Module
⑤ Added Module has appeared on the right panel
Step 8: SkiiiD Code of Gas MQ-6
skiiiD Code is intuitive function-based codes. This is based on skiiiD libraries
getData()
"Return ADC value."
isDetected()
"If detected data is lower than standard retrun true, else return false."
Step 9: Contact and Feedback
We are working on components and boards libraries. Feel free to use it and feedback us, please. Below is contact methods
email: contact@skiiid.io
twitter: https://twitter.com/skiiiD_official
Youtube: https://www.youtube.com/channel/UCfS2RQL3m3hVoHkF...
skiiiD user forum: https://www.facebook.com/groups/skiiiD/
Comments are fine too!
