Introduction: How to Use PyCharm With Raspberry Pi Pico W and MicroPython
About: Keep improving every day, and help others improve too.
Learn how to get set up and start writing code in MicroPython using PyCharm IDE.
Before we delve into the topic, we invite you to support our ongoing efforts and explore our various platforms dedicated to enhancing your IoT projects:
  • Subscribe to our YouTube Channel: Stay updated with our latest tutorials and project insights by subscribing to our channel at YouTube - Shilleh.
  • Support Us: Your support is invaluable. Consider buying me a coffee at Buy Me A Coffee to help us continue creating quality content.
  • Hire Expert IoT Services: For personalized assistance with your IoT projects, hire me on UpWork.
Explore our Stores for Premium Products:
  • ShillehTek Store: Access exclusive discounts on Arduino, Raspberry Pi sensors, and pre-soldered components at our ShillehTek Website.
Shop on Amazon:
Raspberry Pi Pico or Raspberry Pi Pico W
Step 1: Download PyCharm
https://www.jetbrains.com/pycharm/download/#section=mac
The community version is fine for this work.
Step 2: Install MicroPython on Pico
  • Plugin the device into the computer while holding the bootsel button.
  • Go to https://micropython.org/download/ and download the latest version for the Pico or Pico W
  • Drag the UF2 file onto your Pico once it is done downloading. *It should show up on your Desktop as RP1-RP2.
  • Once it is done, the RP1-RP2 will disappear.
  • Unplug and replug the Pico (without holding the bootsel). You need to do this so PyCharm can find the device.
Step 3: Install MicroPython Plugin in PyCharm
  • Open PyCharm, go to Plugins, and download the MicroPython plugin.
  • Restart the IDE
Step 4: Write Code
  • Go to File > Create Project. Create an environment as shown above.
  • Go to Preferences and enable MicroPython as shown here below.
  • You can find the device path on a Macbook in the terminal using the command
ls /dev/tty.*
  • On a Windows this would be a COM port.
  • You can now run code on the device by right-clicking the file and selecting “Run ‘Flash <filename>‘“
  • Add the following code to check if it works by blinking the LED
import machine
import time
led_pin = machine.Pin("LED", machine.Pin.OUT) # GPIO pin 25 controls the onboard LED
while True:
led_pin.toggle() # Toggle the LED state
time.sleep(0.1) # Wait for 1 second
If you run it and you see the LED blinking you did everything correctly, congrats!
Some Pros:
  • Very easy to set up, and benefits of IntelliSense in PyCharm
  • Good for very simple projects
Some Cons:
  • You cannot edit files directly on the device with the IDE
  • You can only run code in the main.py file
  • You cannot run files if you are connected with another IDE like Thonny
Conclusion:
If you learned something here please subscribe to the channel. Let me know if you have any questions, thanks!
