Introduction: How to Use SlideSwitch 10KLineTaper With SkiiiD
A tutorial to develop SlideSwitch10KLineTaper with skiiiD.
Step 1: Launch SkiiiD
Launch skiiiD and select New button
Step 2: Select Arduino UNO
Select ① Arduino Uno and then click ② OK button
*This is Tutorial, and we use Arduino UNO. Other boards(Mega, Nano) have the same process.
Step 3: Add Component
Click '+' (Add Component Button) to search and select the component.
Step 4: Saerch or Find a Component
① Type 'Slide' on the search bar or find the Slide switch 10k Linear taper on the list.
Step 5: Select SliderSwitch 10KLinearTaper
② Select SliderSwitch 10KLinearTaper Module
Step 6: Pin Indication and Configuration
then you can see ③ pin indication. (You can configure it.)
*This module has 3 pins to connect
skiiiD Editor automatically indicate pin setting *configuration available
[Default Pin Indication for SliderSwitch 10KLineTaper Module] in case of Arduino UNO
OUT: A0
VCC: 5V
GND: GND
After configuring pins ④ click ADD button on the right below side
Step 7: Check Added Module
⑤ Added Module has appeared on the right panel
Step 8: SkiiiD Code of SlideSwitch 10KLineTaper Module
skiiiD Code is intuitive function-based codes. This is based on skiiiD libraries
getData()
"Return ADC value depends on knob's position."
Step 9: Contact and Feedback
We are working on components and boards libraries. Feel free to use it and feedback us, please. Below is contact methods
email: contact@skiiid.io twitter: https://twitter.com/skiiiD_official
Youtube: https://www.youtube.com/channel/UCfS2RQL3m3hVoHkFo...
skiiiD user forum: https://www.facebook.com/groups/skiiiD/
Comments are fine too!
