Introduction: How to Use Sugru to Make ARO Rubber Wall
Follow those steps to make ARO rubber wall from Sugru
Step 1: The Stuff You Need
See image
Step 2: Apply the Release Agent
We can use dish soap
Apply a large amount of dish soap on the mold base
Apply the dish soap only at the channel area
Step 3: Add Rubber Wall Stiffener to the Mold
Make sure the stiffener bonding surface is dry
Step 4: Apply Sugru to the Mold Base
Try to push Sugru into the channel
Use paper towel to dry the Sugru bonding surface only
Do not wipe away the dish soap on the mold base
Step 5: Compression Mold Part 1 and Base
Compress the Sugru with both mold pieces
Use your thumb and index finger to push Sugru into the mold
Make sure the stiffener is flushed to the surface
Use craft knife to cut away extra Sugru
Step 6: Remove Mold Base and Clean Up
Remove mold base
Step 7: Remove Molded Piece From the Mold
Remove molded piece with stiffener attached from the mold
Let it sit for 24 hours
Step 8: Post Mold Cure Process
Remove extra part of stiffener base
File the stiffener surface
Step 9: Finish
Done
