Introduction: How to Use XTool M1 to Engrave Cups
About: MADE, the latest innovation of its parent company Hacker Lab, is where dreams become a reality. For over a decade, Hacker Lab has supported countless individuals to “BUILD CODE UNITE”. At MADE, we live by the …
Using the Xtool M1 and Rotary we are going to be able to engrave our names or other graphics into cups.
Xtool M1
Ra2 Rotary
Cup
Step 1: Turn It On
Turn on Xtool M1 and plug into mac laptop
Step 2: Open XCS
Open Xtool Creative space
Step 3: Set to Cylindrical
Set XCS to Laser Cylindrical
Step 4: Use Chucks
Change the settings to use Chucks
Step 5: Measure Diameter
Measure diameter of cup with caliper ( if cup is tapered measure in the middle of where you want to put the image)
Step 6: Set Perimeter
input the diameter of the cup you measured with the caliper. (make sure you input into the diameter box and perimeter will auto calculate.)
Step 7: Connect Rotatory
Make sure rotatory is in place and plugged in (rotary should be nearby or in the machine)
Step 8: Tighten Cup in Place
Place the cup in chucks and tighten with  tool( let the red light land on the middle of the cup and make sure the rotary is straight.
Step 9: Level the Cup
if cup is tapered level the cup using the tiny level and placing shims under the rotary
you can move the shims further down to increase the height.
Step 10: Measure Height
Once the cup is level we need to check the distance if clicking the ruler doesn't bring up the option to use manual measure, simply turn off the laser so you can move the head directly over the cup and use the small ruler placed on the cup to measure to the top of the head. ( when the there's a light behind it its much easier to see what exactly the distance is as it will be whichever mark is dark)
Step 11: Add Image
If you want to add an image click image in the top left and navigate to your image. For text simple click text on the left bar and type in your text
Step 12: Set Up Image
set line near the center of the cup and make sure image is fully on the lit side
Step 13: Set Speed and Power
Click the graphic and Set settings to 100 power and 200 speed
Step 14: Click Start
click off the graphic double check settings and click start
Step 15: Start for Real
Click start again and close the lid then
Step 16: For Real for Real START
Press button on Xtool
